  1. Hi, I have this .MOV video from my friend, he is able to play fine in his Mac book, but when I copied to my Windows PC, it just display black screen,
    the details of the video:
    General
    Complete name : C:\Users\Users\Desktop\Sequenz 2.mov
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 19.3 MiB
    Duration : 44s 933ms
    Overall bit rate : 3 608 Kbps
    Encoded date : UTC 2009-07-24 03:19:06
    Tagged date : UTC 2009-07-24 03:19:06
    Writing library : Apple QuickTime
    Video
    Format : WMV3
    Codec ID : WMV3
    Bit rate mode : Variable
    Bit rate : 3 243 Kbps
    Width : 912 pixels
    Height : 136 pixels
    Display aspect ratio : 6.706
    Frame rate mode : Variable
    Frame rate : 30.000 fps
    Minimum frame rate : 29.412 fps
    Maximum frame rate : 30.303 fps
    Bits/(Pixel*Frame) : 0.872
    Stream size : 17.4 MiB (90%)
    Language : English
    Encoded date : UTC 2009-07-24 02:52:36
    Audio
    Format : WMA2
    Codec ID : WMA2
    Duration : 44s 768ms
    Bit rate : 363 Kbps
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Bit depth : 16 bits
    Stream size : 1.94 MiB (10%)
    Language : English
    I had K-lite codec pack installed on my PC, and I also had tried on few more other PCs with different codec pack installed but still no luck
    is this codec problem or the video is somehow encrypted to play on Mac only?
    Tried VLC?
    But a mov with wmv video.
  3. Yes, I did try with VLC and still no luck.. according to my friend, this video were taken from a Windows PC which worked fine, then passed to his Mac book and then to me.
