    Oct 2009
    United States, PA
    I have used multiAVCHD for some time. And basically I have no problems working with this program. But this time I've got one. Putting an MKV with 3 audio tracks and 3 subtitle streams thru multiAVCHD only video and 3 audio tracks come out as the result of the process (trying to make an AVCHD format). I did the similar processes with multiAVCHD before (MKV with multiple audio tracks and multiple subtitle streams) but this time I've gotten stumped. Any advice, please ?
    EDIT: MediaInfo shows that 3 sub streams are there. They are not. At least MPCHC
    shows no subs when I check for them.
    I remember something now: before I created this AVCHD I had done a scan of Windows Registry and had fixed the errors. Maybe that's the reason of the problem (no I didn't do a backup of previous Registry).
    [13:50:13] Destination path does not exist!
    [13:50:13] Changed to: C:\multiAVCHD\AVCHD\
    [13:50:15] Initialising...
    [13:50:15] Checking for new version...
    [13:50:18] You have the latest build.
    [13:50:18] The lack of support for multiAVCHD development results in major delay of all the updates and improvements.
    [13:50:18] Consistency check finished!
    [13:50:18] Initialization finished. multiAVCHD is ready!
    [13:50:18] 1 year and 351 days since multiAVCHD was published.
    [13:50:18] 397 people supported it with donations
    [13:50:18] and you are the 3893626 one to launch the program...
    [13:50:18] Support multiAVCHD to extend its features and keep it going!
    [13:50:18] multiAVCHD.dat version: [04010767]
    [13:50:35] Audio track #2 name: [DTS English audio]
    [13:50:35] Audio track #3 name: [AC3 English audio]
    [13:50:35] Audio track #4 name: [AC3 Polish audio]
    [13:50:35] Subtitle track #5 name: [English]
    [13:50:35] Subtitle track #6 name: [German]
    [13:50:35] Subtitle track #7 name: [Polish]
    [13:56:30] Checking for available space and drive types (FAT32/NTFS)...
    [13:56:33] Destination [c:]: NTFS, 53887.61 MiB (52.625 GiB) free space
    [13:56:33] Temp folder [c:]: NTFS, 53887.56 MiB (52.625 GiB) free space
    [13:56:33] Log started for multiAVCHD v4.1 (build 770)
    [13:56:33] Selected output mode: AVCHD compatible player (DVD/BD-R disc) [Restricted]
    [13:56:33] Processing one title...
    [13:56:33] Strict AVCHD folder mode is enabled...
    [13:56:33] Processing (C:\Users\Mark\Documents\Workbench\splitted\Casino-001.mkv)...
    [13:56:34] Detected frame reference count: 3 (max:6).
    [13:56:34] Detected video: ID#1:V_MPEG4/ISO/AVC 1280x720, fps=23.976, ref=3
    [13:56:34] Detected subtitles: ID#5:S_TEXT/UTF8 Language: eng
    [13:56:34] Detected subtitles: ID#6:S_TEXT/UTF8 Language: deu
    [13:56:34] Detected subtitles: ID#7:S_TEXT/UTF8 Language: pol
    [13:56:34] Detected audio: ID#2:A_DTS (48000Hz 24bit 6ch 1472kbps) Language: eng
    [13:56:34] Added audio: A_DTS, "C:\Users\Mark\Documents\Workbench\splitted\Ca sino-001.mkv", track=2, lang=eng, timeshift=0ms
    [13:56:34] Detected audio: ID#3:A_AC3 (48000Hz 6ch 640kbps) Language: eng
    [13:56:34] Added audio: A_AC3, "C:\Users\Mark\Documents\Workbench\splitted\Ca sino-001.mkv", track=3, lang=eng, timeshift=0ms
    [13:56:34] Detected audio: ID#4:A_AC3 (48000Hz 6ch 384kbps) Language: pol
    [13:56:34] Added audio: A_AC3, "C:\Users\Mark\Documents\Workbench\splitted\Ca sino-001.mkv", track=4, lang=pol, timeshift=0ms
    [13:56:34] Extracting SRT/SSA/VOBSUB subtitle tracks.
    [13:56:34] Plase wait - it may take a while!
    [13:57:48] Converting to SRT/PGS...
    [13:57:48] Converting TEXT subtitles to PGS/SUP...
    [13:57:48] [casino-001.extr.005.eng.srt]
    [13:57:48] Processing may take some time, so be patient!
    [13:57:48] Advanced subtitle processing (step 1)...
    [13:57:48] Fast mode enabled (1128x184 @ 23.976 fps with 76px margins)...
    [13:59:14] Advanced subtitle processing (step 2)...
    [14:00:29] *** 2 problems of all 1 are fixed!
    [14:00:29] *** Imported subpictures: 1560/1560
    [14:00:29] Conversion successful...
    [14:00:29] Adding external subtitles (Casino-001.extr.005.eng.srt) (eng)
    [14:00:29] Converting TEXT subtitles to PGS/SUP...
    [14:00:29] [casino-001.extr.006.deu.srt]
    [14:00:29] Processing may take some time, so be patient!
    [14:00:29] Advanced subtitle processing (step 1)...
    [14:00:29] Fast mode enabled (1128x184 @ 23.976 fps with 76px margins)...
    [14:01:38] Advanced subtitle processing (step 2)...
    [14:02:44] *** Imported subpictures: 1420/1420
    [14:02:44] Conversion successful...
    [14:02:44] Adding external subtitles (Casino-001.extr.006.deu.srt) (deu)
    [14:02:44] Converting TEXT subtitles to PGS/SUP...
    [14:02:44] [casino-001.extr.007.pol.srt]
    [14:02:44] Processing may take some time, so be patient!
    [14:02:44] Advanced subtitle processing (step 1)...
    [14:02:44] Fast mode enabled (1128x184 @ 23.976 fps with 76px margins)...
    [14:03:54] Advanced subtitle processing (step 2)...
    [14:05:03] *** Imported subpictures: 1477/1477
    [14:05:03] Conversion successful...
    [14:05:03] Adding external subtitles (Casino-001.extr.007.pol.srt) (pol)
    [14:05:03] M2TS stream split set at 0MiB...
    [14:05:03] Creating clip and playlist info (tsMuxeR)...
    tsMuxeR (Version 1.10.6) output:
    Decoding H264 stream (track 1): Profile: High@3.1 Resolution: 1280:720p Frame rate: 23.976
    H.264 stream does not contain fps field. Muxing fps=23.976
    H264 bitstream changed: insert nal unit delimiters
    H264 bitstream changed: insert pict timing and buffering period SEI units
    Decoding DTS stream (track 2): Bitrate: 1536Kbps Sample Rate: 48KHz Channels: 5.1
    Decoding AC3 stream (track 3): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6
    Decoding AC3 stream (track 4): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 6
    Decoding PGS stream (track 5): Resolution: 1280:720 Frame rate: 23.976
    Decoding PGS stream (track 6): Resolution: 1280:720 Frame rate: 23.976
    Decoding PGS stream (track 7): Resolution: 1280:720 Frame rate: 23.976
    H264 bitstream changed: insert SPS/PPS units
    Processed 124321 video frames
    Creation of Blu-ray playlist
    Creation of Blu-ray stream info and seek index
    Mux successful complete.
    Muxing time: 3 min 53 sec
    tsMuxeR meta:
    MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --vbv-len=500
    V_MPEG4/ISO/AVC, "C:\Users\Mark\Documents\Workbench\splitted\Ca sino-001.mkv", insertSEI, contSPS, track=1, lang=eng, fps=23.976
    S_HDMV/PGS, "c:\multiAVCHD\_TEMP\multiTEMP-20101212\srt-82818403.eng.sup", lang=eng, fps=23.976
    S_HDMV/PGS, "c:\multiAVCHD\_TEMP\multiTEMP-20101212\srt-82961986.deu.sup", lang=deu, fps=23.976
    S_HDMV/PGS, "c:\multiAVCHD\_TEMP\multiTEMP-20101212\srt-83098331.pol.sup", lang=pol, fps=23.976
    [14:08:47] Media transfer: 00000 -> 00000.m2ts
    [14:08:47] Processing playlist...
    [14:08:47] Title #1 added: "Casino-001"
    [14:08:47] Verifying title...
    [14:08:49] Title has: 3 audio tracks and 3 subtitle tracks
    [14:08:49] Preparing authoring information...
    [14:08:49] Authoring menu (NTSC).
    [14:08:50] Creating title thumbnails for 1 titles (XMB)...
    [14:08:55] Using 1 thumbnail/chapter links for title #1...
    [14:08:55] *** Extracting 1 chapter thumbnails...
    [14:08:55] *** Chapter #1 [00:00:00.000] set for thumbnail at [00:43:10.041]
    [14:08:57] Image processing for XMB menu completed!
    [14:08:57] Preparing menu pages...
    [14:08:57] Setting main menu for 1 titles...
    [14:08:57] Playback will end after title #1.
    [14:08:57] Playback will start with title #1 (Casino-001).
    [14:08:57] Setting menu properties...
    [14:08:57] Selected TV system: [NTSC]
    [14:08:57] Processing clip (CPI/CLPI) files...
    [14:08:57] Completed.
    [14:09:08] Preparing AVCHDTN database...
    [14:09:10] Database and index created!
    [14:09:10] Done!
    [14:09:10] Saving multiAVCHD quick-load project (mpf):
    [14:09:10] c:\Users\Mark\Documents\Workbench\output from multiAVCHD\1\AVCHD\multiAVCHD.mpf (OK!)
    Compilation summary:
    Format: AVCHD compatible player (DVD/BD-R disc) [Restricted]
    1. Casino-001 [01:26:25]
    Overall duration : 01:26:25
    Output size : 7057 MiB (6.892 GiB)
    [14:09:10] c:\Users\Mark\Documents\Workbench\output from multiAVCHD\1\AVCHD folder created (AVCHD/Blu-ray output)!
    [14:09:10] Burn its CONTENTS to DVD R/RW UDF 2.50/2.60 disc!
    [14:09:11] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20101212\).
    [14:09:11] Your compilation contains 1hrs 26min 25sec of video material.
    [14:09:11] multiAVCHD finished in 758.165 seconds (00:12:38.164)!
    [14:09:11] End of log.
    Oct 2009
    United States, PA
    I had uninstalled Haali Media Splitter and got my subtitle streams back in MPC-HC. I have reinstalled Haali Media Splitter with the default settings and subtitles are still there.
    Apr 2011
    Cambodia
    good to knew that. I have one problem please help me.
    my original MKV has 13 subtitles stream once I imported to multiAVCHD I removed 10 of the subtitles I don't want and I added my own External subtitle but once I completed rendering the project I see only my External subtitle that I added and the rest it available for select also but it won't comes out on the screen at all.
    Any idea how to fix this?
    Thanks.
    Oct 2011
    Biograd
    there is something wrong with multiavchd's support for internal pgs subtitles. SRT (internal and external) work always.
    Oct 2011
    Biograd
    sorry. didn't notice that the original poster had mkv with srt subs.
