Hello,
I've converted several movies with MeGUI and X.264 codec. I noticed, that the AVC level isn't always the same. Some movies have 3.0, 3.1 or 4.0.
The encoder settings for the AVC level is currently set to "Unrestricted/Autoguess". How does X.264 determine, what level to use at this setting? Does it work like "Oh, this movie is quite complex, let's use a higher AVC level..." ?
What, if I set the AVC level to 4.1 ? Will this tell the encoder to use 4.1 as maximum level or will it always use 4.1 and nothing else?
Thanks for the help.
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 07:57 -
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 10:45 -
convert .mkv from level @5.1 to level @4.1
By florinus in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2010, 15:33 -
VC-1 or AVC
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 11th Jan 2009, 09:19 -
Encoding matroska file to AVC level 3
By flash74 in forum ffmpegX general discussionReplies: 2Last Post: 11th Feb 2008, 11:04
