Hi, i have DVD film, and there is menu. I wish to remove it, and change subtitles. I don't know how to do it, where are subtitles, which file ? Can i do this in DVD Lab ?
What's that mean, 'conform subtitles to film'? If you want to add subs to a DVD, follow Baldrick's Method 2 in his guide:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
If you mean you want to synch the subs to the video, then that's much more difficult but there's lots of software available for the job. -
yes, i mean synch the subtitles. i have file, and there isn't when 'line' have to coming in and out
You have a text file with no timings? Use a subtitling program to create your subtitles, ones such as Subtitle Workshop, SubtitleCreator, or Aegisub.
Not good enough. Details needed. Were you able to get the subs muxed into the audio and video with Muxman? That is, when you played the Muxman authored DVD (before doing the 'Replace' step using VobBlanker) did you see subs? This is using a software DVD player, one such as PowerDVD, and not just double-clicking on a VOB. If no subs, check (and post) the Muxman log found in the root of the 'C' Drive.
Or else just give up.
How to change the color of converted subtitles with Txt2Vobsub
By uher in forum SubtitleReplies: 5Last Post: 27th Mar 2015, 11:00 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
ConvertXtoDVD - Can't change subtitles color
By Phil240 in forum Authoring (DVD)Replies: 5Last Post: 8th Dec 2007, 04:03 -
HELP! I just want to add subtitles- I dont want to change anything else
By marklight in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2007, 20:18 -
Change subtitles
By Flying Doctor in forum SubtitleReplies: 8Last Post: 5th Aug 2007, 06:17
