Hi guys how are u??
I'm just wondering why does my subtitle appears pixelated in the movies??
I'm using CONVERTXTODVD Program to convert my movies to DVD and burn it and watch it on TV.
I got nervous from this problem i don't know what to do??? im using the last version and tried to play within the settings but nothing i made the cod page thing ANSI Arabic (My Subtitles is Arabic Language)and also nothing still pixeled So please help me what should i do ????
Here an example
Results 1 to 17 of 17
Well it's almost guaranteed that the .avi movies have already been "destroyed" as far as quality goes. Once the conversion from the original source to "avi" is complete....the quality is gone and there is no way to get it back.
I don't know how you are generating these subs, but the problem is that he outline is not anti-aliased -- is just a black pixel or nothing. You get a smoother appearing outline if it can use tones (eg, greys). Whether this is possible depends on your subtitling program. If you use simple sans serif English fonts (like Arial) this isn't so much of a problem, but more complex shapes don't look so nice.
by pixelated, i assume you are talking about the jaggy edges.
As you are using convertxto dvd, go into the subtitle settings and select FONT, anti aliasing and select "Anti alias - with hinting" this should improve your subtitle quality -
I don't use ConvertXToDVD, so I can't help there. I make my DVD subtitles from scratch but I've had no experience with non-English alphabets. I can't help you. Sorry.
how to add subtitle to X264 movies ?
By fibola in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Jul 2010, 18:00 -
.SUB subtitle file appears to be empty
By dexter30 in forum SubtitleReplies: 4Last Post: 30th Mar 2010, 21:47 -
Subtitle file does not match with movies timeline
By dilanalex in forum SubtitleReplies: 2Last Post: 25th Mar 2009, 00:30 -
subtitle and movies on demand
By sat-jokar in forum SubtitleReplies: 4Last Post: 16th Jan 2009, 13:41 -
how to match subtitle with hd movies ???
By abd640 in forum SubtitleReplies: 3Last Post: 19th Nov 2007, 18:48
