I have a Sony PMW-EX1R videocamera.
I have a problem with some mp4 video files.
I copied them from my SxS card to my Pc's hard drive.
The problem is that i can't open these files with ANY program.I can't edit or play these files.
I am a professional user and i haven't seen this before.
The ONLY program who can play this files is "Avidemux", but still, i can't hear sound, just the image!
I can send you a video sample if you want to check it.
Please help me find what's happening, and solve this problem.
Results 1 to 12 of 12
some and not others? different recording modes? or just some of the files?
vlc, smplayer, mpchc all play xdcam fine . It's just mpeg2 in mp4 container
In order to get WMP to play it, you need to install a mp4 splitter and mpeg2 decoder (e.g. ffdshow , with mpeg2 enabled in the configuration)
Most NLE's support xdcam (e.g. premiere pro, vegas pro) . But you need to rewrap to MOV if you are a MAC user with FCP -
no, it is not the codec, i have a really serious problem quys...
i've tried all this codec things.
I have many videos that i rec them by the same way.
this is the only time that the videos doesn't play.
i think that the SMI file is broken (It is in the same folder as the video is). -
Do you mean the files are corrupted ? That doesn't make sense if avidemux can open them. Did you try the other programs listed?
Some players are directshow based - this could mean you have directshow filter issues. The other players (e.g. vlc, smplayer even avidemux) are not directshow based (don't rely on system installed codecs and splitters) - so if they work ok in those, it really suggests a configuration problem
Does your NLE have problems opening them ?
Upload a small sample to mediafire.com or directly here if <30MB -
are you using the xdcam ex clip browser to transfer the files? if not the spanned clips may not transfer correctly.
Problem with Remuxed MP4 Files
By snowfi6916 in forum Video ConversionReplies: 3Last Post: 17th Feb 2012, 02:21 -
Problem with MP4 files and VirtualDub on W7
By asterixvader in forum Newbie / General discussionsReplies: 0Last Post: 10th Dec 2010, 16:09 -
a problem opening MKV or MP4 files
By gis4ever in forum Video ConversionReplies: 10Last Post: 7th Jul 2010, 12:39 -
Audio playback problem on mp4 files...
By Turrican80 in forum AudioReplies: 1Last Post: 1st Nov 2009, 17:18 -
mp4 files to dvd, problem
By jordigrij in forum Authoring (DVD)Replies: 1Last Post: 30th Dec 2008, 12:44
