The subject says it all. I have a Samsung Camcorder HMX-200 that takes nice footage, but Sony VMS 10 does not import the audio properly. I can take the audio from the video and turn that into MP#, then rejoin it with the original video, but I am looking to accomplish two things here and would liek to know if someone has a simple solution. I would like to be able to join the 2gig files before bringing them into VMS 10 AND have the audio import properly (converted during the joining process).
Any ideas?
I am sure I am doing something wrong. The program seems straight forward, but I cannot get the program to join the files together. Can you describe the process so that I can see if I am doing it right? And is there any kind of manual that describes h"how to use" the program?
I did that and when I ran the program, it did not join the files... hmmm... any other thoughts?
I should add that the program will mux 40.1% of the 3 files I am trying to join and say that it is finished.
The actual tsMuxer output says the following:
"SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net Decoding H264 stream (track 1): Profile: Main@4.2 Resolution: 1280:720p Frame rate: not found
H.264 stream does not contain fps field. Muxing fps=59.96
H264 bitstream changed: insert nal unit delimiters
H264 bitstream changed: insert pict timing and buffering period SEI units
Decoding AAC stream (track 2): Sample Rate: 48KHz Channels: 2
H264 bitstream changed: insert SPS/PPS units
Processed 101917 video frames
Mux successful complete.
Muxing time: 31 sec"Last edited by drguitar; 14th Dec 2010 at 13:00.
BUMP...
No thoughts anyone?
I have also tried TSSplitter to join the files and it also does not put them together.
Vegas movie studio 11 -- need to burn AVCHD file to DVD
By malcolm1 in forum Newbie / General discussionsReplies: 14Last Post: 8th Nov 2011, 02:12 -
What is the difference between Vegas Pro and Vegas movie studio platinum
By jbitakis in forum Newbie / General discussionsReplies: 4Last Post: 18th Feb 2009, 00:41 -
Sony Vegas Movie Studio/DVD Architect Studio
By DJL82 in forum EditingReplies: 8Last Post: 1st Feb 2008, 15:14 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 18:53 -
Speeding up Dell Dimension for AVCHD and Vegas Movie Studio or New Comp
By sierra1049 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jul 2007, 18:15
