Recently, I purchased a Sony widescreen studio monitor to monitor my Hi Def video productions via component signals. In the past, when I had a CRT Sony studio monitor I would hold a blue filter in front of it and then display color bars and make adjustments to calibrate it. This new monitor has a "blue only" feature on it which would make life easier if this is something that I should still do to it. What I'm wondering is if I still should calibrate this studio monitor in the same fashion as I did with my old CRT monitor. Being that it is an LCD monitor should I still approach it the same way? Does it need to be calibrated?
Thanks...
Results 1 to 1 of 1
Calibrating luminance levels/color for capture from VHS
By Cherbette in forum Capturing and VCRReplies: 188Last Post: 29th Sep 2011, 20:18 -
Recommendations for calibrating a westinghouse lcd hdtv?
By yoda313 in forum DVB / IPTVReplies: 30Last Post: 16th May 2011, 14:12 -
Calibrating a monitor
By OldMedia in forum DVB / IPTVReplies: 8Last Post: 2nd Nov 2010, 18:10 -
Can I use a headrest monitor as my server monitor when traveling
By regtcnlgy in forum ComputerReplies: 4Last Post: 17th Aug 2009, 07:43 -
? On calibrating my TV monitor
By sdsumike619 in forum EditingReplies: 1Last Post: 4th Nov 2008, 00:29
