  1. I try to convert a AVI (i did some before who were working fine) to an svcd with tgmgenc, but there is one who made this error! An error occured when audio was decoded, so it cant start the conversion... I tryied to cut the first min to see if it work with AVICHOP but i cant figire how to cut the first meg with this program , it only cut at the end and i'm a newbiie with every programm , so if it's the problem , please , say to me which programm i could use or please if you got the same problem and you solve it , say to me how !!!. thx!!!
  2. The divx file has compressed audio so simply uncompress it either using avi2wav or the 'uncompress' program that comes with avi2vcd.
    I find that the 'uncompress' program works better as it uncompresses the audio to the pmc format rather than mp3 (like avi2wav output).
    Hope this helps!
