I am about to buy a reasonably blu ray burner. Which one should I get?
Well, you have "best" in your title and "reasonable" in your text. Might want to determine which is more important.
For the best, I'd recommend the Pioneer BDR-206 or the earlier model, the 205
For reasonable, go with the LG WH10LS30K -
Thanks!
I have checked them. I will get the Pioneer. -
I highly recommend the Pioneer as well...and they're getting cheaper:
http://www.amazon.com/Pioneer-Internal-Blu-ray-Writer-BDR-206/dp/B0046K062C -
*** Now that you have read me, do some other things. ***
why is the Pioneer better than say a Lite-on?
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106346 -
Only the specs give any real difference ... some just prefer the pioneer's and talk up other brands as being the lesser ... Ive had both brands and found pioneers reliable and robust but finicky with older discs which is why mines the iHBS212 unit.
Lite-on came to blu ray burning a bit later and their first burners were not giving consistent burns on blu ray media. Early impressions hang on for a while. LG's have always been known to be picky about media and are not too good about firmware updates. Pioneer wins because the quality of their burns has been good, they don't have many incompatibilities with media and are well made (at least for modern burners).
Which Blu-Ray writer are you using?
By golfnut in forum Blu-ray RippingReplies: 26Last Post: 2nd Apr 2012, 10:23 -
How do you connect an internal Blu-ray drive to a laptop?
By rayden54 in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jan 2012, 11:31 -
what's the best blu-ray writer available?
By nick101181 in forum DVD & Blu-ray WritersReplies: 8Last Post: 20th Feb 2010, 05:45 -
Blu-ray reader (rom) or Blu-ray Writer?
By gll99 in forum DVD & Blu-ray WritersReplies: 9Last Post: 25th Aug 2009, 14:26 -
Blu-ray in Apple MacBookPro upgrade? internal slot loading?
By rjamesd05 in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Mar 2008, 03:58
