Just wondering if any experts could help me with this problem. I'm trying to get this MP4 to play on my Xbox 360 with the help of TVersity, but it doesn't seem to work. This is the first MP4 I've come across that hasn't worked on my Xbox 360. I'm sorry for being such a noob, but all I know is that files over 4 GB won't work on the 360. This is not the case though, so I have no idea what to do
If anyone could tell me what the problem(s) is and give me any specific suggestions to fix it, I would really appreciate it
Here are the details from MediaInfo:
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.81 GiB
Duration : 1h 42mn
Overall bit rate : 2 532 Kbps
Encoded date : UTC 2010-10-19 17:26:42
Tagged date : UTC 2010-10-19 17:26:42
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 8 frames
Codec ID : avc1
Duration : 1h 42mn
Bit rate mode : Variable
Bit rate : 2 132 Kbps
Maximum bit rate : 19.3 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.096
Stream size : 1.53 GiB (84%)
Title : HDLiTE
Writing library : x264 core 107 r1745 4785e8e
Encoding settings : cabac=1 / ref=8 / deblock=1:1:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.42 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=2 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=2pass / mbtree=1 / bitrate=2132 / ratetol=2.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=none
Encoded date : UTC 2010-10-19 11:44:48
Tagged date : UTC 2010-10-19 17:28:40
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 1h 42mn
Bit rate : 398 Kbps
Maximum bit rate : 473 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 292 MiB (16%)
Language : English
Encoded date : UTC 2010-10-19 17:28:02
Im no expert and I am actually a PS3 man myself so I dont know what is playable on the Xbox 360........
I would speculate about the aac audio though...............most files have ac3......so it might be the audio that is the problem.....
Again, no sound advice as I dont know the details of the xbox playback........sorry -
Too many reference frames. Your file has 8, but the 360 will only accept a maximum of 3. Also, your AAC audio has 6 channels, the XBox will only handle 2 (stereo audio only).
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 09:52 -
MP4 Issue On Xbox 360 (please Help!)
By Cornholio77 in forum Media Center PC / MediaCentersReplies: 9Last Post: 1st Jan 2012, 00:09 -
Can I play this MP4 file on Xbox 360?
By Algamish in forum Media Center PC / MediaCentersReplies: 7Last Post: 26th Jun 2010, 14:34 -
Need something like an xbox 360 to play mp4 on tv
By avalanche165 in forum Newbie / General discussionsReplies: 9Last Post: 15th May 2008, 17:35 -
Capturing Xbox 360/Would This Work?
By njosnavelin78 in forum Capturing and VCRReplies: 0Last Post: 4th Jun 2007, 01:03
