Results 1 to 12 of 12
  1. Hi MrC,
    I'm having a little issue with chapters on a 29.997 framerate avi file. They are not being inserted by muxman for some reason. I have had success with PAL avi files which is strange. I have attached the main log file as well as the muxman log file. The chapter points aren't appearing in the muxman log file.
    You'll notice from the main log that this isn't the original log. I saved the *ac3 and *mkv file and tried a few different chapter settings in the hope of getting it to work.
  2. Hi adyf,
    what is the chapters configuration you are using ('Edit Title'/'Chapters')?
    Bye
    MrC
    AVStoDVD Homepage
  3. MrC,
    I tried various combinations but started out with Preferences - 'Chapters Interval' - set to 5 mins, and 'Use source chapters list' - ticked. Then on Edit Title - 'Auto chapters setup' - ticked. I was of the opinion with this arrangement that if source chapters were present they would be used, but as there aren't any they would be created every 5 minutes.
  4. That's exactly the rationale used by AVStoDVD.
    Do you get something like that in 'Edit Title'/'Chapters'?
    Bye
    MrC
    AVStoDVD Homepage
  5. That's exactly how it was configured. Any ideas?
  6. I cannot replicate the issue, so it is very difficult to understand. To have Muxman create chapters there's should be a "C:\Users\Clare\AppData\Local\Temp\DVD_0_full_Chap ters.txt" and the corresponding command lines in "C:\Users\Clare\AppData\Local\Temp\DVD_0_BatchMux. ini":
    -cellfr "D:\Movies\DVD\DVD_0_full_Chapters.txt"
    -progfr "D:\Movies\DVD\DVD_0_full_Chapters.txt"
    -chapfr "D:\Movies\DVD\DVD_0_full_Chapters.txt"
    Bye
    MrC
    AVStoDVD Homepage
  7. Would it be possible to add a feature to the edit title window that creates a chapter point for every video source? -- for example, when creating a DVD consisting of multiple music clips. Thanks for a great program.
  8. Originally Posted by pm1315 View Post
    You can already do it: just add your titles, then click on 'Menu'/'Tools'/'Join Source Titles'. You will be asked to keep a chapter point at the end of each title.
    Bye
    MrC
    AVStoDVD Homepage
  9. There is no chapters.txt file being created for some reason. At what part of the process should this be created, before or after muxman is running?
  10. It is created just before Muxman (BatchMux) starts. If it can help, this is the VB code:
                    Chapters_List = ""
                    With OutputMediaInfo
                        If .ReadMediaInfo(frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & ".m2v", , False) = True Then
                            Chapters_List_Array = Split(Title(Tj).ChaptersList, " ")
                            VideoFrameCount = Int(Val(.VideoFrameCount))
                            If Val(.VideoFPS) = 23.976 Then
                                VideoFrameCount = VideoFrameCount * 29.97 / 23.976
                            End If
                            For jj = 0 To UBound(Chapters_List_Array)
                                If Val(Chapters_List_Array(jj)) < VideoFrameCount - 5 * FPS Then     ' 5 seconds safeguard
                                    Chapters_List = Chapters_List & Chapters_List_Array(jj) & vbCrLf
                                End If
                            Next jj
                        Else
                            Chapters_List = Replace(Title(Tj).ChaptersList, " ", vbCrLf)
                        End If
                    End With
                    Set OutputMediaInfo = Nothing
                    If Chapters_List <> "" Then
                        NumFile = FreeFile
                        Open frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & "_Chapters.txt" For Output As #NumFile
                            Print #NumFile, Chapters_List
                        Close #NumFile
                        If modUtil.GetFileSize(frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & "_Chapters.txt") > 0 Then
                            BatchMux_ini = BatchMux_ini & "-" & Segment & "cellfr """ & frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & "_Chapters.txt""" & vbCrLf
                            BatchMux_ini = BatchMux_ini & "-" & Segment & "progfr """ & frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & "_Chapters.txt""" & vbCrLf
                            BatchMux_ini = BatchMux_ini & "-" & Segment & "chapfr """ & frmMain.Txt_Path_Output.Text & "\" & TitleName(Tj) & "_Chapters.txt""" & vbCrLf
                        End If
                    End If
    Bye
    MrC
    AVStoDVD Homepage
  11. The code is a little bit technical for me I'm afraid. I do have the following observation however I'm not sure if it's of any significance. If I encode with HCenc 2 pass vbr there are no chapters created in the resultant DVD. However if I encode with QuEnc 1 pass vbr then the chapter.txt file is created and the resultant DVD has chapters. Do this shed any light on this situation?
  12. I just noticed from the DVD_0.log file that the output m2v file is detected as follow:
    MPEG-2 Video - 9450 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Progressive (TFF) - 1 seconds - 40 frames
    2 issues: very high bitrate (should be max 9000 kbps) and duration (should be 1:57:51 hours as input file). It seems that MediaInfo is detecting a wrong duration when your input file is encoded with HCenc. And what about bitrate, have you changed the default settings?
    Bye
    MrC
    AVStoDVD Homepage
