I can't decoding AVC video with virtualdub.
I try to open with the quicktime plugin (the video is an mp4) but says "unable to initialize quicktime:initializeQTML".
I try to check "ask for extended option after this dialog" an to use "ICP decomp" and "MovieTask".
I try to open with the DirectShow input driver but says "... does not have a video stream".
In the ffdshow VFW interface the AVC decoder is in "libavcodec".
What can i do?
opened with the DirectShow input driver, i try to click the second play button (output playback) and i can see the video (the decoding works)
if i click on the first (input playback) it says "The decompression codec cannot decompress to an RGB format. This is very unusual. Check that any "Force YUY2" options are not enabled in the codec's properties" -
That's some long standing bug in VirtualDub. Try forcing ffdshow to output RGB. Note that you will be using DirectShow decoders, not VFW, when using the DirectShow plugin.
It might also be possible to force the input colorspace in VirtualDub via Video -> Color Depth. Not sure about that though.
How to open AVC and AAC in VirtualDub (AviSynth/DShowPlugin)?
By klischee in forum EditingReplies: 37Last Post: 8th Aug 2014, 02:38 -
!4 Q's? .flv avc virtualdub and convert hq ipod?
By angles in forum Video ConversionReplies: 4Last Post: 20th Aug 2010, 11:26 -
Problem in decoding audio in WMV3 video file
By sapfeer in forum Software PlayingReplies: 6Last Post: 16th Mar 2010, 14:09 -
Enabling AVC Core in Virtualdub?
By drwho in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2008, 20:22
