Results 1 to 20 of 20
  1. Hi, i Converted a dvd movie INCEPTION to x264.mkv (Constant quality) using handbrake but i noticed a lot of grain in video, as the source video itself is bit grainy, is there any way to remove this grain 7 improve the video quality ? i ripped this new dvd using dvd fab decrypter. please suggest me if u got any idea, thanks in advance.
    skorpinok
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Obviously the bitrate was set too low....just re-rip the DVD/Blu Ray and convert again.
  3. Originally Posted by hech54 View Post
    What ? He said the source was grainy . A higher bitrate will help preserve the grain
    Filter it with degraining filters before encoding. Not sure if handbrake has any built in , but there are dozens in avisynth to choose from
    Feb 2004
    Australia
    You may find this link helpful in explaining the use of common filters in vdub for noise reduction ... avidemux as well
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then he should return the defective DVD or Blu Ray and get his money back. HTF can the original DVD or Blu Ray be grainy?
  6. Originally Posted by hech54 View Post
    You're joking right ? You've been a member here how long ?
    Film grain. In fact, Hollywood often adds extra grain in post production. Let's not get into the subjective argument as to whether or not grain looks better - but just know it's often the director's decision to add it
  7. Originally Posted by hech54 View Post
    Maybe the film grain is comes from the actual film (might be larger silver particles or something, probably done because it is what the director envisioned the look of the film being when making the film).
    OOPS...a bit late
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Now you're joking right?
    Even the trailers for Inception on YouTube don't look grainy. There MUST be another reason.
  9. Originally Posted by hech54 View Post
    You've reached this conclusion based on a youtube trailer ?
    I hope you realize youtube re-encodes everything at a low bitrate. Even if you wanted to keep grain, you couldn't.
    Now I haven't seen the Inception blu-ray . Maybe it is grainy or maybe it isn't. Maybe something is exceptionally wrong with skorpinok's copy, or maybe it's just normal.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I think you hit the nail on the head with that one.
  11. Member classfour's Avatar
    The Heartland, United States
    Yeah, like it may be a download - not a rip.
    ;/ l ,[____], Its a Jeep thing,
    l---L---o||||||o- you wouldn't understand.
    (.)_) (.)_)-----)_) "Only In A Jeep"
    Oct 2010
    England
    It's likely that noise reduction and/or low bitrate have removed the grain from the YouTube version. Can you post a link to the YouTube trailer you're looking at?
    Virtually all films have noise/film grain to some degree. I'd much rather have a DVD/Bluray disc with film grain, rather than have excessive noise reduction applied - which usually affects fine detail and textures.
    I've got an Inception trailer that's ~9Mbit/s - and it has quite noticeable grain on a number of shots.
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Absolutely unnecessary....see classfour's post.
    Oct 2010
    England
    I don't follow. classfour seems to be suggesting that the original video might be a poorly converted download rather than a bit-for-bit rip of the original DVD. In most cases a badly converted video will loose grain rather than add it.
    The YouTube versions I've seen are a lower quality with visible macroblocking (set the resolution to 720p):
    http://www.youtube.com/watch?v=66TuSJo4dZM
    This higher bitrate version shows grain in some shots, particularly behind Michael Caine at 32 seconds (167MB download):
    http://playlist.yahoo.com/makeplaylist.dll?sid=107193280&sdm=web&pt=rd
    This might be explained by the different film formats used in the film (35mm anamorphic, 65mm and VistaVision) and possibly the use of higher speed (ISO) film stock for certain scenes.
  15. I tried with new DVD, also tried with other inception Dvd's the grain is present all over the film especially in dark scenes & low lightning conditions, also tried with stax rip using 2 pass encoding(x264 film medium), its all the same result just like handbrake ouput nothing change, i think this is christhoper nolans grainy inception, while his dark knight i encoded using same tools is fantastic.. Dream within a Dream
    Oct 2010
    England
    Could you post an image from the DVD as an example of the grain?
    Although I can see grain on some shots from the trailer, it's quite subtle. Applying noise reduction might actually reduce the quality by removing detail, so I personally wouldn't use it here.
    Have you tried Bjs' suggestion (VirtualDub)?
  17. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    OF COURSE you did. How many did you buy at one time?
  18. Originally Posted by skorpinok View Post
    Because fast film is grainy. Grain is your friend. Learn to live with it.
  19. applying noise reduction using Denoise ('Weak') in handbrake will spoil my encoded picture quality? is it ok accept noise & grain in movie as natural? i think if the first attempt fails then later one is acceptable
  20. Originally Posted by skorpinok View Post
    It depends on how much grain you have. If there's a lot of grain a "weak" noise reduction won't do much. "Strong" noise reduction will remove small details as well as noise. Heavy noise reduction will also lead to posterization artifacts.
    Of course. Have you ever seen a movie in the theater? They're full of grain.
