I've recorded a clip with a camcorder and an audio track with a computer which is wired up to a lapel mic. now i need to combine and sync the audio and video.
the video is mp2 (old camcorder) and the audio can be any format (I used audacity).
What you could try is to mux the audio and video together, keeping the original files intact, then play the muxed file in MPC( HC). You can adjust the audio offset there. Once you get the sync right, note down the audio offset, then add that to the file and check it. If it's correct, save out the files as a direct stream copy, no encoding. I do this with VirtualDub, but for MP2, AVIDemux may be a better choice.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
How to sync video with audio
By Denster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2010, 21:25 -
Best way to sync audio/video for part of a video
By marioval in forum EditingReplies: 2Last Post: 19th Mar 2010, 12:30
