So here's the history. I got a new device and it can play video off SD cards and from a USB drive. I spent quite a bit of time trying to get the encoding right. I've looked through the manual, Google, etc. The only way I was able to encode a video to get it to work on the device was to use an older version of Handbrake (0.9.3) and encode the file as an Mpeg-4 XviD with AVI as the container. That worked perfect. However, I'd like to use the latest version of Handbrake, or even different software if that will work. Here's the list of acceptable formats according to the manual.
I've tried every program I can think of. Some of them work sometimes, some give me errors for certain videos and not others. I just want to be able to batch convert a bunch of files at once. So far the closest I've got is using StaxRip. It worked on a few files for me, but on others gave me errors. The only luck I've had is encoding with AVI as the container. Nothing else has worked for me.
Any help or suggestions would be great. Thanks.
It clearly states the only supported video formats are DivX (v3, v4, v5.2, v6) in .avi or .divx. Only the DivX® encoder from divx.com encodes in a .divx container, which leaves .avi (mpeg-4 part 2) as the only option for any other encoder.
So I'm a bit puzzled why you want to give up on software that works (HandBrake 0.9.3)? -
I've tried so many different programs in the last few days and I don't remember 100% why I moved on from Handbrake. If I remember correctly, as soon as I try to scroll through the video on the device I'd lose sound.
I'm trying DivX converter right now... I also tried this at some point in the last few days and stopped using it for some reason. I need to start making notes
I saw it listed m4a in there as well, but I wasn't able to get any m4a files to play. -
Yea, DivX Converter created a good file on my computer but in the device it says 'Unplayable Format'
Ok, I was able to get DivX converter to work on some files but not all. For the ones it isn't working for I'm using the older version of Handbrake again and it works.. But as soon as I try to move around on the video I lose all sound.
What is the model and manufactuer of this device in video?
By sullivang in forum Capturing and VCRReplies: 1Last Post: 17th Feb 2012, 19:49 -
Best video capture device
By sanray19 in forum Video ConversionReplies: 8Last Post: 23rd Oct 2011, 16:04 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
Video device to PC and TV
By starerik in forum Capturing and VCRReplies: 3Last Post: 11th Apr 2009, 10:49
