N00b question:
I want to play the WDTV Live in a room that has a PC that is already setup with a 5.1 surround system system.
WDTV Live ---> PC/Soundblaster Audigy 2 ---> 5.1 speakers.
Is it possible to get "digital surround sound" from the WDTV Live to the Soundblaster Audigy 2?
If the Audigy card has a digital input, probably. The WD has a optical digital output, but I had to convert mine to coaxial digital for my existing coaxial audio setup. The optical and coaxial audio content is exactly the same. You can use a converter like this: http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=...seq=1&format=2 You also need a short Toslink optical cable to connect to the converter, then just a RCA type coaxial audio cable to the sound card.
The back of the sound card has a 3.5mm mini-jack line input. I don't think it's digital though.
Would it still work?
Edit: If this matters, my 5.1 system is setup/connected from the sound card's three 3.5mm analog outputs: (1) front L/R, (2) center/subwoofer and (3) rear L/R.Last edited by Stealth3si; 11th Dec 2010 at 20:41.
There seem to be quite a few configurations of a Audigy 2 card. You would need to research your specific model to see if it has a digital audio input. You definitely need a digital audio input for what you want to work.
WDTV Live Plus or PS3?
By tj1182 in forum Newbie / General discussionsReplies: 12Last Post: 31st Jul 2010, 22:31 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 08:50 -
WDTV Live (non Plus)
By stiltman in forum Media Center PC / MediaCentersReplies: 181Last Post: 12th Jun 2010, 17:46 -
DTS on WDTV LIVE?
By bagmand22 in forum Media Center PC / MediaCentersReplies: 3Last Post: 28th Jan 2010, 11:09 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 22:45
