I have no Bluerayburner yet so I have to make a DVD from my HDV-films. I usually edit these films in HD-format in Vegas.
I have note been very satisfied with the DVD-quality. I have now discovered the reason is that I should not use the HD-file for burning a DVD. It is better to make a separate AVI-file in SD-format and then use this file for the DVD.
Of course I could make the AVI-file in SD-format directly from the camera but then I would have no edited HD-file for future use.
when you're done editing the HDV project, render to dvd compliant mpeg-2 and ac-3 audio. then use those in an authoring program to make menus, chapters and convert it all to vobs, bups, and ifos.
no avi files required. -
see your other thread.
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 10:09 -
Making documentaries: Camera and software suggestions?
By nopEda in forum Newbie / General discussionsReplies: 4Last Post: 3rd Aug 2008, 16:07 -
how come no one is making a HD video camera that uses DV tapes ?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Jan 2008, 05:53 -
making a DVD from an old Video camera tape
By oreocharlie in forum Authoring (DVD)Replies: 5Last Post: 17th Dec 2007, 13:39 -
General Guidance and Hardware req. for making VCD with Digital Camera
By dpilot83 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jun 2007, 05:53
