I'm hoping someone can help with this. I have an avi file that has two audio streams, both French and English. French is coded as the primary language.
If I load the file in VirtualDub, how do I separate and save the English audio stream? Should direct stream or full processing mode be enabled for audio? And once I've loaded the file, and choose File, Save, Wav - only the French wav is saved.
Could someone please let me know what steps are involved in capturing the audio in English and then saving this back as an avi file? Thanks.![]()
Results 1 to 1 of 1
Separating Audio Layers From .AVI File
By PhoenixOrion602 in forum AudioReplies: 2Last Post: 6th Jan 2011, 00:58 -
separating audio and re-authoring
By joecass in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2010, 11:37 -
Separating the channels in a 5.1 stream into separate streams
By FallenAngelII in forum AudioReplies: 2Last Post: 7th May 2010, 03:37 -
Separating audio
By Jeikobu in forum MacReplies: 12Last Post: 9th Jun 2008, 05:39 -
separating audio files
By lordwade in forum AudioReplies: 1Last Post: 11th May 2007, 04:32
