I am playing an avi in a window and freeze it.
I take a full desktop screenshot, but the avi window is saved as black.
How do I take the shot so that the avi window is visible too?
It's because of video overlay/hardware acceleration. Some screen capture tools allows this directly or just use mpchc, open video, file->save image. Paste the screenshot into your full desktop screenshot.
edit: You could also start two video players with the same video and one should't use video overlay so it should be possible to take a normal screenshot. -
Will it exactly fit in the Black area? Because I want to preserve the player's window frame.
That is not an option, because I want to preserve this particular player's window frame which I want to relay to the party I am taking the screenshot for.
This might be what I need.
Can you suggest any?
Thanks -
Does MPHC alter the color quality, at all?
Sometimes screen caps do that, and it's not accurate.Want my help? Ask here! (not via PM!)
To tell you the truth, I had Classic player in my system, I do not know if it is the same as Baldrick's link.
Perfect quality was not what I was looking for... all I wanted to do is fill the exact black box I had before with a decent frame capture and it served my purpose.
If it is the quality of the frame itself you are interested, there are other ways to get a quality one, but you would not get the GUI frame that I wanted.
Movie Screenshot Program?
By Junkee in forum Newbie / General discussionsReplies: 2Last Post: 27th Mar 2010, 05:15 -
screenshot from mkv files
By dtommy79 in forum Software PlayingReplies: 1Last Post: 14th Feb 2010, 11:33 -
need automated screenshot from many videos.
By lordhutt in forum ComputerReplies: 3Last Post: 11th Aug 2009, 14:33 -
Video screenshot help
By KateP in forum Newbie / General discussionsReplies: 9Last Post: 27th Apr 2009, 01:39 -
Creating Video screenshot
By tuanvn.2007 in forum Video Streaming DownloadingReplies: 4Last Post: 21st Sep 2008, 09:37
