When updating (the free version of) DVDFab, is it best to uninstall first, before installing the new version?
Or can you just install the new version over the old version without any problems?
Their site says "DVDFab will check for a new versions automatically, but you must perform the update manually." and I wasn't sure if that meant to uninstall first.
The only time I seem get a prompted to update, is whilst DVDFab is reading a DVD in the drive. It doesn't seem right trying to update the program whilst it is reading a DVD so I haven't tried following the prompts.
Many thanks for any replies.
It sounds like the update function is working correctly - but at an inconvenient time.
Try starting DVDFab without a disc in the drive, allow it to check for updates before you proceed (you'll get a popup).
You don't have to uninstall the program, it installs over the old one - but will require or force a restart of DVDFab.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Thanks for the reply classfour, I will try without a DVD and see if I get the update popup.
DVDFab 8.1.6.3
By tarzan54 in forum DVD RippingReplies: 3Last Post: 12th Feb 2012, 22:06 -
DVDFab 8.1.3.8
By hardy in forum DVD RippingReplies: 30Last Post: 21st Dec 2011, 05:50 -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 16:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 13:02 -
Is DVDfab still the best?
By jason in forum Newbie / General discussionsReplies: 38Last Post: 14th Jun 2009, 08:40
