  1. Not clever enough LaxerFL's Avatar
    Jun 2006
    I use TVersity to stream my media locally to my PS3 and now over the internet to my HTC G2. I'm having a hard time figuring out what format to use to achieve the best compromise of quality and speed. Even with 3G/HSPA+ I can't just stream a 1.5gig, hour and 30 minute video smoothly. I also get an "illegal file" error when trying to stream .avi's.
    I am using Handbrake to encode using H.264 in an .mp4 container. My phone's resolution is 480x320 but I don't want to encode everything to that resolution because at home via my PS3 I watch on a 42inch HD tv.
    Can anyone suggest a good compromise between file size, resolution, compression, etc? I have the latest version of Handbrake and TVersity. Ideally I would like the source material to be in the highest possible resolution and have TVersity downsize it for streaming to my phone only while sending the high reso to the HD TV. I have not had much luck getting TVersity to transcode on the fly. My computer has plenty of resources for it, I just don't think I have the program configured properly.
    Any ideas, suggestions, or tips would be greatly appreciated.
    Thanks much and Happy Holidays,
    LaxerFL
    ps, pretend I'm an idiot and that I need everything spelled out, lol! Thanks again
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You'll need to encode twice. One optimized for 480x320 and another for your HDTV.
    Alternate for a single file is to find the limit for the HTC G2 (maybe 480x480 or 640x480 at supported bit rate) and live with lower quality on your HDTV. That will require experimentation.
    http://www.kiva.org/about
  3. Not clever enough LaxerFL's Avatar
    Jun 2006
    I was slowly coming to that conclusion... Thanks for the input. I think I'll setup an experiment today and encode the same clip a few different ways and see what works best. I've kind of been doing that but a little willy-nilly.
    Thanks,
    LaxerFL
