Another question for the AviSynth gurus!
I have an uncompressed RGB AVI that i'm feeding through an AviSynth script before conversion.
I was wondering if I have placed my "ConvertToYV12()" command in the right order:
#ASYNTHER Default (AVISource)
AVISource("E:\XYZ project\Uncompressed AVI exports\Sequence 01 (lagarith RGB).avi")
ConvertToYV12()
RemoveGrain()
Tweak(sat=1.15)
Lanczos4Resize(720,304,0,60,0,-56)
LimitedSharpen()
It seems logical to get the colorspace conversion out of the way first, and it produces nice Xvid files.
But the reason I'm asking is that when I feed the same script into Staxrip for x264 MP4 encoding, the modified output script generated by Staxrip itself has the command ConvertToYV12() inserted again in the last line.
Any ideas?
Your placement is correct (and necessary), as RemoveGrain only accepts planar (YV12) input.
Staxrip always adds ConvertToYV12 at the end, since it doesn't 'know' whether you already have one in your script.
If the output is already YV12 at that point, ConvertToYV12 will do nothing, so no time is wasted.
question about batchfile "taskkil" command for audiorepeater.exe
By Ennio in forum AudioReplies: 0Last Post: 12th Apr 2012, 10:17 -
Determining correct order in AVISynth Script?
By Killer3737 in forum Newbie / General discussionsReplies: 6Last Post: 22nd May 2011, 11:28 -
Moving the "Run" command
By CSULB71 in forum ComputerReplies: 10Last Post: 8th Dec 2010, 18:07 -
"smoother" plugin for avisynth script
By Lastman369 in forum Video ConversionReplies: 5Last Post: 21st May 2010, 13:17 -
AviSynth: script command, order of execution, and 'coding efficiency'
By hollowman in forum Newbie / General discussionsReplies: 6Last Post: 27th Aug 2008, 23:44
