Video has sound ONLY when "audio => audio channels => right" is checked, it does not have sound at any other settings. Why??? How do I correct this problem? I'm using VLC player.
Thanks in advance!
Results 1 to 11 of 11
Sounds like phase cancellation. If it happens with all audio files, check your speaker/headphone connection (whatever you are listening through). If the problem is isolated to only one file, well, something is wrong with that file.
Phase cancellation would require that the audio was being mixed to mono (or Dolby Surround Sound decoding with no back speakers). But there would be sound with only the right channel, as well as with only the left channel.
The one thing I can see that would explain all the symptoms is Dolby Surround Sound decoding with no rear speakers and a dead right speaker). When Stereo or Reverse Stereo are selected the surround sound decoder will route the out of phase sound to the rear speakers (which don't exist). With Left channel only sound would only come out of the left speaker. With right channel only sound would come out the right speaker -- but if the speaker is blown or disconnected there would be no sound. Of course, it should be obvious the rigth speaker is blown when playing other audio sources.Last edited by jagabo; 10th Dec 2010 at 22:01.
container:
File Length Correct
AVI v1.0
Interleave: 1 vid frame (33 ms)
Audio frames: Aligned on interleaves
Video: 26.3 MB (76.39%)
Audio: 6.75 MB (19.59%)
AVI Overhead: 1.38 MB (4.02%)
audio codec:
0x0055 MPEG-1 Layer 3
44100Hz 64 kb/s tot , Joint Stereo
video codec:
XviD 1.1.2 Final -
I would use VirtualDub.
1) File -> Open Video File
2) Video -> Direct Stream Copy (no reencoding the video)
3) Audio -> Full Processing Mode
4) Audio -> Use Advanced Filtering
5) Audio -> Filters... filter audio as necessary
6) Audio -> Compression -> Lame MP3
7) File -> Save as AVI
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 16:44 -
no video but sound playing video with MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 30th Mar 2008, 04:05 -
video but no sound
By chas638 in forum Newbie / General discussionsReplies: 2Last Post: 24th Jan 2008, 06:39
