Hey guys,
I'll try and describe clearly what i'm trying to set up.
I have 4 PC's with capture cards that are connected to 4 XBOX 360's in a single room. I would like to be able to stream the footage from the 4 360's to another computer in a different room. That computer would like to see all 4 of the streams on a single screen.
What hardware/software would I require to set something like this up?
Thanks for any information!
One way would be to use a multiplexer like security systems use. http://www.supercircuits.com/Video-Multiplexers/QS29 The downside is it's composite only and you need a monitor that has a composite input, IE, a TV.
Or you may be able to use another capture card in the PC used for the display of the four images and some software tricks to stack all four images. Avisynth might be able to help there. But you would still likely need composite inputs for the card.
But other here may have some better solutions.
And welcome to our forums.
Thank you very much Redwudz!
Regarding the multiplexer. The room with the computer/tv i want to have the 4 screens viewable on is on a different floor than where the 360's are. I would not be able to run a wire from the 360's to the multiplexer. That removes it as an option doesn't it?
Convert DVD to avi with 5.1 audio to stream to 360
By johnmactavish in forum User guidesReplies: 7Last Post: 14th Jun 2011, 18:49 -
WMV movie will stream from PC but not NAS (360)
By mikemar in forum Media Center PC / MediaCentersReplies: 8Last Post: 29th Jul 2009, 21:08 -
i need this to stream on xbox 360
By carlos28355 in forum Video ConversionReplies: 17Last Post: 1st Jul 2009, 19:18 -
Stream .iso to my Xbox 360
By nfl2k2 in forum Media Center PC / MediaCentersReplies: 3Last Post: 21st Oct 2008, 17:43 -
Stream MKV to Xbox 360
By spork985 in forum Media Center PC / MediaCentersReplies: 2Last Post: 21st Jun 2008, 06:35
