  1. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    This is sort of a "for next time" question since I found a work-around and the clips are done but...
    I had a 1 minute clip I needed to turn upside-down and backwards(mirrored) for a "driving in Australia" joke. I also had an audio clip that I wanted to add to the video....which was within 5 seconds duration of the video clip's duration. The clip was already sped up in AviDemux(the only thing I have that opens MJpeg clips reliably), outputted as HUFFYuv so VDub would accept it. I just need to adjust the framerate again to match the audio duration. The only problem is...the audio speed/pitch changed as well. I checked and unchecked the "Sync To Audio" box....nothing changed....the audio(44.1 WAV) was still playing very slowly. What did I do wrong? I also tried to remove the audio...then add it again hoping that would make it ignore the framerate change....nothing.
    My workaround was to get the audio clip and video to end precisely at the same time....remove the audio then output video only as a new file....then open the new file and re-add the audio(then of course to Xvid for uploading).
    Not vitally important that this is resolved....it's just bugging me. Thank goodness for big hard drives....
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    V=AviSource("video.avi")
    A=DirectShowSource("audio.wav")
    length=AudioLengthF(A)/AudioRate(A)
    frames=FrameCount(V)
    V
    FlipHorizontal()
    FlipVertical()
    AssumeFPS(frames/length)
    AudioDub(A)
    Jul 2009
    Spain
    I would have done it AlanHK's way too, but to answer the question re VirtualDub, it should work if you simply select, in the Video Frame Rate dialog, the option "Change so video and audio durations match", no more, no less.
    I don't see a "Sync to audio" box (using version 1.8.6), but maybe that's the same thing in your version.
    EDIT: There is a 'sync to audio' under the Options menu, but that's just for playing the preview within VirtualDub and doesn't affect the output.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I have 1.8.5.....maybe I should upgrade someday huh?...
    Jul 2009
    Spain
    I probably should too (latest is 1.9.10), but the "Change so video and audio durations match" option is also available in 1.8.5.
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Found it....never noticed that before....
    Thanks....
