Greetings,
I have an avi file in DV format that was made with FAST DV Master Pro some 10 years ago, and I'm trying to get it to play in XP. At first it only played video without sound in WMP, but after installing AC3Filter it does have sound, but it's all garbled. It sounds as if it's playing 100x faster than it should.
According to GSpot, the audio is 0x2000 (Dolby AC3) 48000Hz 1728 kb/s tot (2 chnls).
Isn't that 1728 bitrate extremely high?
I have tried playing with some of the AC3Filter settings and some of them make the audio 'less garbled', but that's it. Is there some other AC3 filter or setting or player I should try? I also tried VLC but it does not play sound.
Thanks.
Very odd. If it is a true DV-format .avi file, then the audio stream should be PCM wav, not AC3. Where did the .avi come from, and how was it originally captured and saved? Seems like someone did something wrong somewhere.
The avi was captured from a MiniDV cam to the FAST DV Master Pro card through firewire. It was me who did this capture and maybe I messed things up, but it's been so long that I don't even remember the name of the editing software that came with the card...
Avidemux - WMV file convert to MP4 - Audio stream garbled
By belltown in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 15:52 -
Split Avi to DVD creates Video_Ts folders w. garbled video intro. Help?
By wildgeese in forum ffmpegX general discussionReplies: 7Last Post: 10th May 2011, 18:56 -
tsMuxer + TrueHD = garbled sound
By picrade in forum Blu-ray RippingReplies: 11Last Post: 11th Jul 2010, 22:05 -
Garbled frames + sound hickup when capturing to external drive
By ByronFortescue in forum MacReplies: 5Last Post: 21st Apr 2008, 07:28 -
Help Topic, AVI playing garbled
By Sueng in forum Software PlayingReplies: 3Last Post: 23rd Mar 2008, 16:14
