hey all, I'm really new to ffmpeg and ffmpegX, so forgive me if i'm saying horrible things...
I make a dvd magazine every 2/3 months, and so far I've been exporting everythin with adobe media encoder, and I reached a very good DVD quality after messing around a bit with the settings.
then I went crazy with these 40 hours encoding, and decided to make the move to ffmpeg, through ffmpegX. and wow what a difference in time !
however all the encoding i tried gave the same results, which are something i used to get when our premiere pro sequences were set to "interlaced" with progressive footage : kind of lines along dark edges...
that's what makes me think that ffmpegX interprets my footage as interlaced, when it's progressive. I couldn't find any option to change that.
here is my workflow and settings:
from premiere
export edit with progressive footage to progressive prores codec (1280*720 1.0)
in ffmepgX I'm doing first H264 to show to everyone involved the result in HD, and then mpeg2 to put that into encore
export h264 with x264, 5000 kb/s, 1280*720 16:9
options checked : CABAC, 2passes
AND
export mpeg2 ffmpeg, 7000kbps, PAL
options checked : high quality, 2 passes
as I said both encoding give these weird lines
I attached two screenshots
thanks for your help !!!
ben
Are you referring to the light line on the face just below the cap's shadow? That would be contrast enhancement, probably from a sharpening filter.
I don't see the tell-tale signs of interlacing in your screenshots. Interlacing effects should be perfectly horizontal, and should be visible every other scan line.
i'm refering to the lines one can see in picture at the left, at every edge between colors of different brightness.
around the whole cap, and around the eye's shade is the most visible i think. they look horizontal to me...
I just checked on ffmpegx, no enhancement are on.
thanks for your help anyway case, I appreciate it
I see. That effect could be the result of a line-doubler, just like the most basic de-interlacer -- throwing away half the vertical resolution.
I'm not sure how ffmpegX fits into this (unless you set the Deinterlace checkbox in image filters), as I haven't seen this effect on my conversions with this tool.
What is the playback software that you used when capturing these screenshots? Have you ruled out any de-interlace settings in there?
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
de-interlaced means progressive ?
By codemaster in forum EditingReplies: 19Last Post: 23rd Dec 2010, 06:08 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
Progressive vs Interlaced Regarding Motion
By Brent212 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jul 2009, 19:26 -
encode interlaced material witth ffmepg to MPEG2 but get progressive output
By Massa in forum ffmpegX general discussionReplies: 9Last Post: 13th Jan 2009, 12:42
