Results 1 to 11 of 11
    Nov 2007
    Every time i add any avi file to toast to convert it to a burnable file it quit. I mean as soon as i drop it in toast it quits
    . WHY!!!!! Does anyone have an answer. Thanks in advance. Please help its killing me.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Obviously Toast doesn't like what is inside of that .AVI file. Not all .AVI files are the same.
    Nov 2007
    It is doing it to all my avi files.
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    What type of AVI files does Toast accept?
  5. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Toast accepts any AVI file that QuickTime Player also accepts. That is, Toast hooks into QuickTime architecture for decoding AVIs.
    Originally Posted by thasco View Post
    As soon as i drop it in toast it quits.
    A few crashing problems with Toast can be linked to its Preferences files. Try trashing the Toast plist and prefs files in your User>Library>Preferences folder and relaunch Toast to see if this fixes the problem.
    Nov 2007
    When i trashed the toast plist file emptied the trash then relaunched toast and it still quits only when i try to add an avi. Also the toast plist file never came back. WHAT CAN I DO!!!!!
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    MediaInfo works on Mac. Find out what is inside the AVI file that you know crashes Toast.
  8. Toast is terribly slow for video conversion, i usually use VisualHub or similar app for such conversions.
    VideoSpec also works well for identifying the nature of A/V sources.
  10. Member MacDSL's Avatar
    Dec 2002
    San Francisco
    Is Quicktime able to PLAY the file?
  11. Member terryj's Avatar
    N35°25.24068, W097°34.204
    I second MacDSL...if it crashes Quicktime, then either your .avi file is bad, or
    your in need of some serious downtime using Disc Utility to clean up
    and diagnose the state of your Hard Drive. If a known good .avi file
    that you have played in the past also crashes Toast or Quicktime Player,
    I would seriously then look at cleaning up your Hard Drive, first with Disc Utility,
    then second look into how much Free Space you have on the disc.
    the fact that the .plist file for Toast didn't regenerate points to a problem with the Hard Drive.
    Once Toast was relaunched, that .plist should have regenerated.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
