I've been trying to mask some videos in Adobe after effects. Doing some testing, found that when rendering, the output video is of very poor quality. There are what I believe are dropped frames. The video is very jerky. The issue is that some years ago I had done it and the videos looked perfect. Now, getting back into the process, I can't find a way to get the same quality products I usad to get. The original video is mpeg. Any idea?
From that detail ? No.
What format are you rendering to ?
What are you testing the playback on ?
Your computer specs in your profile indicate a very old, under powered machine. Playback of newer codecs or high resolution would most likely cause it to struggle and produce less than smooth playback.Read my blog here.
Vegas Pro 9 has audio problems when rendering!
By Tahlos in forum AudioReplies: 0Last Post: 19th Jun 2010, 11:47 -
Problems with audio rendering - Sony Vegas 9 Studio
By bridgeperson in forum EditingReplies: 5Last Post: 5th Jun 2009, 09:55 -
Rendering problems Premiere Pro CS3
By tangosalon in forum EditingReplies: 2Last Post: 15th Jan 2009, 14:29 -
Wondering about malware, and how they effect sync problems
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2008, 06:22 -
Having Problems Rendering & Authoring with 1 Video File...!
By tug_hill2 in forum Capturing and VCRReplies: 1Last Post: 20th May 2008, 02:27
