Hi, please excuse my beginneriness.I'm more experienced with audio than video and am getting into video. I am Mac-based.
I need to buy a video camera and have two use cases I would like to solve.
1) Recording a puppet show. Camera mounted on a tripod, aimed at a puppet above a table. I'm under the table operating the puppet and I need to see what the camera sees, either from laptop (preferable; lighter) or small tv. Camera is recording, to tape or computer. Good-quality sound needs to be recorded too from multiple external mics.
2) I am sitting at the piano, playing and singing on camera. Camera is on a tripod pointed at me. I'm also recording the mic'd piano (two mics) and the mic'd voice (singing into mic) so the video can have very good sound. I would need to be able to either record to tape/computer OR live-stream from this setup.
Ideally, the same camera could handle all these cases, which means I could even live-stream a puppet show if I wanted. Meaning, a dv camcorder with usb or firewire that works on the Mac? I might consider two so I could record two angles at once. What are some good camera options I should be looking into here? Ideally I'm spending under 2k for everything I need for the complete setup (I already have a Macbook Pro).
I'm not interested in getting into serious photography, or doing serious movie-making, so smaller form factor is better. This will always be for videos that end up being on the web, but I do want nice-looking high quality web video.
Thanks!!!!
tangrams
Does your MacBook Pro have a Firewire port?
Explain how you would live stream? Over Ustream? BitGravety?
Is there a second person to switch cams and mix audio?
Your requirements are complex.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Yes, my macbook pro has firewire, and I think we can assume that my future laptops will have firewire because so much of my audio hardware requires firewire. Like I won't be dumping the MBP for an Air or anything. It sounds like firewire is better than USB for this kind of thing?
I haven't decided how I would live stream yet - I would experiment with ustream or justin.tv or quicktime broadcaster or whatever, but I have a lot to learn in this realm - is it necessary to know this for myself before I get the camera?
I'd probably pre-set up the mixing and leave it alone while I'm performing. And then in the cases where I record, I'd mix it afterward. I guess in the case of recording I was imagining I'd be replacing the video's built-in audio track with the separate audio recording using Logic Pro (which I have), but I don't know how this would work for streaming. So no, I don't think I'd be relying on there always being another person there. The cameras would be stationary, etc. -
Is it possible to do this with one cam with manual repoint? The multi-cam switching while live is the budget breaker. You could do a second cam B-Roll to tape/flash for inclusion during editing.
Streaming live h.264 video from WiFi camera directly to iPhone.
By mpopovi in forum Video Streaming DownloadingReplies: 4Last Post: 2nd Jan 2012, 19:25 -
Streaming Live
By Black-Logik in forum Video Streaming DownloadingReplies: 0Last Post: 20th Mar 2009, 19:03 -
Live Streaming
By futurewebboss in forum Video Streaming DownloadingReplies: 5Last Post: 8th Mar 2009, 19:57 -
Camera suggestions for live streaming
By jbaugh in forum MacReplies: 6Last Post: 14th Dec 2008, 19:06 -
Streaming Live
By Tucker19 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Nov 2008, 09:00
