Hello friends,
I have got many HD films(H.264 & AAC) ranging from 3-6 GB but they are consuming all my disk space. I have seen compressed HD videos with small sizes and unnoticable quality loss .so i am assuming that i can convert my films without much quality loss.i want them to be re-encoded to 2 GB (1.5 GB video and .5 GB audio).searched on google about this but seems pretty much confusing since there are many software & encoding methods to do this .so i request the video experts to suggest which s\w ,encoding method should i use to yield the output which can save my time and quality.sorry if i have posted in the wrong thread.
Thanks in advance
Results 1 to 11 of 11
I don't think there is any difference in the encoding time, since they're all x264.
The main differences seem to be which options are exposed in the GUI, but I doubt even that is not
that big of a deal - unless you're an x264 expert, in which case you'll probably be using the command line.
Try the popular ones and see what you likle. Handbrake, Staxrip, xvid4psp, etc,etc... -
Thanks guns1inger for Ur opinion.here is a sample of HD video i want to re-encode.can you explain 'generous bitrate' for this file(video stream alone 3 GB).so that i can encode them to 65% of source file without affecting quality as you said.
Video bitrate is ~3200 kbps at 1280x544 px.I dont have much experience in downsizing HD videos, but I think you could down to ~2000 kbps. If you want to go even lower you should also consider resizing.
thanks leghorn for your concern.so i want my 3 GB video to convert to 1.5 GB so how many kbps should i use or should i prefer two pass encoding.
Half the bitrate of your source. Because:
file size = bitrate * running time
Nobody will be able to tell what the resulting quality will be because every video requires a different bitrate to maintain quality. A slideshow with no transitions can be encoded with very low bitrates and look fine. A video with a lot of noise and action shots will require lots of bitrate.
You should always use two pass encoding if you want the best quality at a particular file size. -
Thanks to everyone who has taken time to reply to my thread.I have also got the optimum settings for x264 conversion from the following guides.hope it will be helpful to others.
http://www.videoforums.co.uk/submit-your-own-guides-reviews/23573-h-264-encoding-x264-...round-far.html
http://mattgadient.com/2009/09/12/the-best-h-264-x264-settings-for-handbrake/Last edited by kurian; 9th Dec 2010 at 22:39.
Yes I have seen mp4s on some which are even around less than 700-900MB and quality for those mp4s are just incredible. I have reencode avatar extended gtom blu ray to mp4 but seems not to get below the 2gb mark using xmedia recode and it is terribly time consuming. Any other tools besides those mention and add subtitles as well? XVid4PSP does not work with Windows 7 64 bit somehow on mine anyway.
Download Streaming Videos Without Quality Loss
By Eva-Unit01 in forum Video Streaming DownloadingReplies: 6Last Post: 13th Sep 2010, 00:22 -
Converting MOV PhotoJpeg to h264 without quality loss.
By JRM in forum Video ConversionReplies: 3Last Post: 2nd Mar 2009, 22:46 -
converting vids w/o quality loss
By majax79 in forum EditingReplies: 3Last Post: 24th May 2008, 01:58 -
Quality loss in converting from DIVX to XVID?
By fwtong in forum DVD RippingReplies: 7Last Post: 25th Jan 2008, 17:37 -
Converting HD-DVD Rips to MP4 Without Quality Loss
By mpalm887 in forum DVD RippingReplies: 1Last Post: 10th Jan 2008, 11:14
