Looking for Cam :: has at least a 30mm lens for wide --works fairly well in low light -- allows LANC --Not tape and not AVCHD--- using only XP Intel w/ 4gb...........We are coming from years of a Sony TRV 20 ---great camcorder just not that quality in low light>> and the 1 hour limitation.
Any ideas
Results 1 to 13 of 13
Buy a good used Sony VX-2000 or VX-2100 (includes wide lens).
For > 1 hr. record to a Focus FireStore or a laptop.
Or this HVRDR60
http://www.audiolines.com/Video-Gear/VJ-Gear/Video-Hardware/Sony-HVRDR60-HDV-HARD-DISK-RECORDERLast edited by edDV; 7th Dec 2010 at 14:15.
http://www.kiva.org/about -
The SONY is a tape cam -- so that won't work.... we film theater/orchestra /bands , many have a duration longer than a hour session . ALready have that problem for years of trying to change tape. I used 3/4 VHS in the 80's with 36 lb cameras on my shoulder and the low light meant 3pm in the afternoon
Then forget about LANC.
How do you use LANC?Last edited by edDV; 7th Dec 2010 at 22:55.
I have a fluid head with handle allowing zoom controls, etc <<< plugs into a LANC jack on SOny ( and some Canons ,,,,,, I believe )
Any thing available on the market ::: besides the ultra-expensive SONY HVRD 60 ??
The DV recording hard drives are expensive because they need to implement a deck with user interface and control. Focus Firestore is the top brand. Still when a used DV camera + Firestore are budgeted, the cost is still less than a flash based prosumer camcorder only. Flash media is very expensive.
Further, in larger cities, you can rent a Firestore.Recommends: Kiva.org - Loans that change lives.
Worst part of a TRV 20 --the tapes load from the bottom ~!! Off the tripod ..then pop out the old .......
looking for an upgrade -- just the next generation would probably suffice >>>will search ////////Last edited by cjogo; 9th Dec 2010 at 18:11.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
Newbie wanting help?
By Mark75 in forum Video ConversionReplies: 1Last Post: 30th Oct 2008, 15:13 -
Wanting to distribute HD all over the house
By Onceler2 in forum DVB / IPTVReplies: 6Last Post: 17th Feb 2008, 22:30
