I have had a Funai hdr b2735d for about 2 years now it was a nice bit of kit at the begining with a dvd player/burner, a hdd and vhs with cross dubbing on all, but after about a year it decided not to burn to any dvds and for the last 6 months it has trouble reading/playing commercial dvds (movies) i have searched the net about this and have come to the conclusion it is just a poorly made bit of kit, as it sems this is a common problem and using laser cleaners only helps for a while, so im thinking can i just replace the dvd/burner unit, go out buy a dvd/burner like the ones you fix into a pc and put it in this unit, first off the problem i can see is the 'open tray' funtion as pc dvd/burners has a button on the front and the funai has a button on the unit to open the tray is there a way around this or is the whole idea unworkable. thanks all.
Results 1 to 1 of 1
HDD not Recognized After MB Replaced
By jollyjohn in forum ComputerReplies: 16Last Post: 14th Feb 2012, 02:49 -
Unique problem with ALL Funai VCR's
By 389poncho in forum Newbie / General discussionsReplies: 13Last Post: 31st Oct 2009, 16:58 -
HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???
By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38 -
hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Aug 2008, 17:28 -
My Funai DVD Recorder Won't Record?
By rhem in forum DVD & Blu-ray RecordersReplies: 12Last Post: 15th Aug 2007, 15:08
