Hi there,
Was wondering if would you recommend some inexpensive camcorder (up to $800-1000) to record video with audio from a mixer. Need high quality audio (input from a musical instrument via a mixer). As I see many cams do not have any audio input today besides the internal microphone? Is there any possibility to use a camera to record video directly onto the hard disk and audio via the computer audio in?
Thanks in advance!
One of the things that make inexpensive camcorders inexpensive is the absence of sophisticated external audio inputs. You can find camcorders with mini-pin audio inputs and buy an XLR adapter with level knobs from a place like BeachTek, but you may still face problems with mic and line impedance mismatches. There is also the option of recording the audio from the mixing board using a separate digital recorder (like the Zoom H4), then match up and replace the audio track on your video, using good video editing software. (This is what I would do.)
As for simultaneously capturing live video and analog audio directly to the computer--best to abandon that idea. I really don't think it could be done--at least not without the risk of introducing errors and freezing up the system. -
Hunt for a new camcorder with excellent audio quality
By techspark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 3rd May 2012, 17:02 -
Authoring high quality audio DVD
By carlmart in forum AudioReplies: 14Last Post: 17th May 2010, 08:40 -
Audio issues with high quality rips..
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2010, 20:28 -
SVP camcorder T200 is high quality for youtube?
By yunakokimama in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 11th Nov 2008, 09:27 -
High definition conversition and keep same video/audio quality.
By Itsmeshane in forum Video ConversionReplies: 4Last Post: 22nd Nov 2007, 09:03
