  1. Hey everyone,
    So I downloaded one of the lecture videos available from www.coursesaver.com using Replay Media Catcher 4 which saved it into an flv file. The problem I have is that when I play the file using Moyea FLV player, the elapsed time on the video file seems to go over its designated time. For example, if the file is 21:00 min long, when I play it, it goes over the designated 21:00 min and this is a problem for me because I can't rewind or go forward on the file properly. Does anyone know what the problem may be? Should I try converting the files I have into something else? Thanks a lot everyone.
  2. Try fixing it with FLVMDI
  3. Hey k,
    I don't know what that program does but it seems to fix the problem! Thanks a lot! If you don't mind me asking, what seemed to be the problem with the .flv files I've been downloading?
  4. They seem to lack information about their duration, it usually happens when they were recorded from a live source.
