I capture using ATI AIW. I use VirtualDub with Huffyuv and capture to AVI. I encode using the TMPGEnc VCD template on High Quality. When I play the CD on my stand-alone DVD player, the picture is OK, but there always seems to be "motion" going on, i.e. there always seem to be a million square pixels "dancing around" which makes the video look "computery." This is especially true on dark solid backgrounds. Is this how VCD is supposed to look? Is this the best I'm to expect from digitization? My source is usually VCR using composite connections, but I also experience this using S-Video coming from a satellite receiver. I have a 1ghz Pentium III and 128mb RAM.
when using the High quality feature, I think it has an option as slow quality or something like that. This produces a better quality you can also increase the bitrate and the VBR setting is best
conversion square to non square pixels???
By jakeotr in forum Video ConversionReplies: 7Last Post: 27th Jan 2012, 01:53 -
Square pixels or 16:9 Pixel aspect ratio?
By Scherwin in forum Video ConversionReplies: 6Last Post: 18th May 2010, 13:47 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
should use square pixels or not for 16:9?
By j.man in forum Video ConversionReplies: 5Last Post: 4th Mar 2008, 22:28
