Region Unlocking Bluray and DVD
1. Turn the Blu-Ray on and open the Tray Door
2. Then press the following number combination on the remote “9113“
This will bring up a screen which will allow you to change the region.
3. You have the choice of entering a region code for both Blu-Ray and DVD. I recommend you only change the code for the Blu-Ray component and leave the DVD box empty.
You will need to scroll to the second box and enter either “1“ “2“ or “3“ depending on the region you wish to use.
4. Save the settings by pressing OK and you should be able to watch discs from your selected region.
Results 1 to 9 of 9
Sounds like bullsh!t to me.....especially since Blu Ray "regions" are not numbers.
This Onida Bluray player is an exact replica of the Kogan Region free Blu-ray player sold in Australia. Let heck54 know this first. I am posting the hack after confirming on my own.
The Kogan looks like the Curtis DVD 1102 so if the Onida is a clone of those units then the region change will work. Check the review of the Kogan here:
http://www.cnet.com.au/kogan-blu-ray-player-339293969.htm -
I for one seldom believe 1st time posters....posting hacks about a completely unknown player....that are completely unprovable....who feel the need to send me private messages in an attempt to defend themselves.
heck54 don't think that you know everything. I sent the private message because of your 'Bullshit' message. Onida is a leading consumer brand in India.
Recommendation for Blu-Ray player that can have region free DVD
By noob1391 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Oct 2012, 07:17 -
looking for region free code for a new LGBD550 dvd/blu-ray player
By sassi in forum Latest Video NewsReplies: 2Last Post: 1st May 2011, 02:11 -
Samsung BD-P1600 region hack & Sherlock Holmes Blu-Ray issue
By Mighty_Morpheus in forum DVD & Blu-ray PlayersReplies: 1Last Post: 18th Aug 2010, 13:09 -
Opinion - easiest blu-ray player to hack region free?
By burninglow in forum DVD & Blu-ray PlayersReplies: 0Last Post: 13th Jul 2010, 00:17 -
Samsung BD-P1500 how to get the blu-ray region free or area a & b
By zeus in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Dec 2008, 11:02
