I have used VOB2MPG PRO succesfully on XP both interactivly and using batch command lines. Have just built a new Windows 7 Premium machine and have all the latest updates. Installed VOB2MPG. Initially had a problem with missing codecs but have resolved that by downloading the K-Lite codec pack. Can now create MPGs from HDD DVD files within the interactive window of VOB2MPG. However when I try to convert the same files using a command line the VOB2MPG window flashes on the screen, showing the DVD title/chapter content, then vanishes without any conversion taking place. No output file is produced. In the cmd (DOS) window the batch command appears to have executed without any obvious errors.
Single line example from batch file looks like this:
"C:\Program Files (x86)\VOB2MPG PRO\VOB2MPG" /v="G:\DVD Backup\A Knights Tale\VIDEO_TS\VIDEO_TS.IFO" /o="F:\MPG Films\A Knights Tale" /MainTitle
I get a resultant log file in .....\Badger I.T\VOB2MPG PRO\logs\vob2mpg-20101206121645
which has the following content:
************************ SYSTEM INFORMATION ************************
***************************** VOB2MPG *****************************
Title: PRO
Version: 3.2.0000
Executable: C:\Program Files (x86)\VOB2MPG PRO\VOB2MPG.exe
Executable size: 917 KB
Executable size in bytes: 939091
Executable CreationTime: 28/10/2010 20:18:50
Executable LastWriteTime: 03/12/2010 15:20:48
Executable LastAccessTime: 03/12/2010 15:20:48
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 29.9 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 683 GB
DeviceID: E:
FileSystem: NTFS
FreeSpace: 736 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 1.35 TB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 402 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 870 GB
********************* END OF SYSTEM INFORMATION ********************
/v="G:\DVD Backup\A Knights Tale\VIDEO_TS" /o="F:\MPG Films\A Knights Tale" /t=1
12:16:45
Extracting from Title: 1
12:16:45
12:16:45 =============== Virtual File Details ===============
12:16:45
12:16:45 VTS_03_1.VOB : Length = 1073739776 (0.99 GB) : vPosition = 1073739776 (0.99 GB)
12:16:45 VTS_03_2.VOB : Length = 1073739776 (0.99 GB) : vPosition = 2147479552 (1.99 GB)
12:16:45 VTS_03_3.VOB : Length = 1073739776 (0.99 GB) : vPosition = 3221219328 (2.99 GB)
12:16:45 VTS_03_4.VOB : Length = 1007898624 (961 MB) : vPosition = 4229117952 (3.93 GB)
12:16:45
12:16:45
That's it. No obvious errors. No output file. For it to have got this far I am assuming my syntax is correct and that the program is observing pathing OK. I am now at a loss. Any ideas/help would be appreciated. I have tried various options and have executed the script against 150 DVD files with the same result.
I believe your syntax is wrong. Should be something like:
i.e giving a filename for the mpg.Code:VOB2MPGPRO /v="C:\My DVDs\VIDEO_TS.IFO" /o="C:\VOB2MPG Output\The fog.mpg" /MainTitle
Chrissyboy. Thank you for fast response. How silly do I feel. Just missing the ".mpg" on the output file. Just goes to show you can look but cannot see. Appologies for being a pillock. Now processing batch file as I write at approx 1 DVD per min.
Problem solved.
Windows 7 64bit Video processing software?
By Browncoat in forum Newbie / General discussionsReplies: 3Last Post: 26th Apr 2010, 06:37 -
VOB2MPG command line problem
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Mar 2010, 13:58 -
VOB2MPG-Pro Finished processing 0 vobsets
By jay782 in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 4th Oct 2009, 02:10 -
feature request: Vob2mpg pro command line option for audio stream selection
By Ahimoth in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th Sep 2009, 05:42 -
Error when launching VOB2MPG 3 PRO in Vista Ultimate 64bit
By ghostwulf in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 20th Mar 2009, 05:28
