Please help!
After my DVD to SVCD conversion, I am getting A green bar at the bottom of my movie. I am using DVD2AVI and the newest TMPEG. When I preview the movie with Window Media Player I get a breif message that it is trying to request the codec. Then it says that it can't find it and plays the movie. I tried playing with PowerDVD XP and see the same green bar. I have been double checking my settings and the are the same with Past conversions. The only thing that I can think of is that this may have started after I removed the dvd software player that came with my Gateway PC and installed PowerDVD XP. Any thoughs? Is my codec that TMPEG bad?
PLEASE HELP!! I would like to start encoding as soon as I get a new DVD player to watch them on. (My Pioneer was smashed during a move)
I was right, it was my install of PowerDVD XP. TMPEG was try to encode with a "Cyberlink" codec. I will take off PowerDVD and try again. -
No luck, TMPEG still "encodes" with a codec that nothing can play!
I put back the old DVD plyaer that came with my Gateway PC and nothing helps. Can you point TMPEG to the correct codec? Or should I install a good MPEG2 codec? (Maybe the one in Nimo?)
Somebody please help me out! -
This is nothing u should worry bout, i know what u are talking about.
If u watch ur svcd in wmp or software dvd player, u can see this bar, its not that big but there.
The good news is this-
When u play it back on tv, it will not be there and this is why-
When u play movies back on tv, the whole outer part of the movie vertical and horizontal is cut off by 1-2", causing the green bar to disappear!
So, dont worry, just about all svcds i believe do this in tmpgenc.
Some of them do it to me, some dont. But it never shows on tv.ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one.
Green Bar at bottom problem solved!
By DeniseAck in forum Capturing and VCRReplies: 0Last Post: 9th Aug 2011, 18:19 -
Premiere Pro CS5 Green Bar, Smooth Playback, Choppy Export
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 27th Jan 2011, 22:38 -
Green bar on right side during playback
By rytomi@msn.com in forum Software PlayingReplies: 0Last Post: 27th Oct 2010, 19:12 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 14:39
