hi
i have the k-lite codec pack and when i play a video with mpc home cinema i looks very grainy but only when its dark in the video.
here is a example on how grainy it is:
http://yfrog.com/61grainypicturej (click on the picture to make it big then its much more easy to see how grainy it is) so what do i have to change in the codec settings to fix this?
When i play it in vlc it looks much better, so i guess it should be something that easy to fix in mpc
btw its a mkv file
nvm problem has been solved i just needed to turn of the setting that lets the GPU help processing the video
thinkor,
If you're using MPCHC, why do you bother with a so called 'codec pack'?Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
grainy dark video Help
By timbo2288 in forum RestorationReplies: 36Last Post: 17th Apr 2015, 17:48 -
Grainy video footage
By ccorwin in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2011, 01:24 -
MPC and MPC-HTPC Video Sizing
By ron spencer in forum Software PlayingReplies: 8Last Post: 15th Dec 2009, 10:52 -
Video quality is grainy
By Mysterio in forum Newbie / General discussionsReplies: 14Last Post: 5th Mar 2009, 12:03 -
Help With Grainy Looking Video
By MAXIMUS01CAN in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 30th Jan 2008, 16:00
