Every time i try to join 2 AVI files together in Virtual Dub, the audio goes out of sync. When you play back the new file, the first half is perfectly in sync... but when it gets to the second half, as soon as it starts playing the data from the second file, the audio goes out of sync. I've tinkered and toyed with this for hours trying to find a solution, but with no luck. If anyone can help me out, it'd be appreciated.
There could be a slight difference between the two AVI's, in fact one of them might have bad frames.
Try loading them into Vdub 1.49 select video and audio streaming and save out another copy (Streaming takes a min or so). Do the same with part 2, then join the new ones together.
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 09:56 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 13:35 -
Virtual Dub Audio Not In Sync
By RKelly in forum EditingReplies: 2Last Post: 28th May 2008, 19:45 -
Audio out of sync after running file thru virtual dub
By AORMan in forum Video ConversionReplies: 3Last Post: 2nd Oct 2007, 13:35 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
