    Dec 2010
    Croydon, Surrey, uk
    Firstly sorry if this is in the wrong section.
    i have an ICY Box IB-MP302-B HDD Media Player. it has been working fine. today i have added some films from my pc but whilst it was connected i did a disc defrag. now when i connect it to my tv it just shows up ROOT and no other files or folders.when i connect it back to my pc all the files and folders are there. i dont know if the disc defrag has caused this. any ideas how i get it back to normal?
    many thanks
    gary
  2. Reboot and re-initialise the Icybox. Backup all your media to somewhere else, then re-format the hard drive as per the icyBox manual. then copy 1 of your files back to the disk and test it. If it works, copy all the files back and carry on as normal. If it doesn't work, implement Plan C.
    Never do a disk defrag while your IcyBox is connected to your PC.
    The electronic components of the power part adopted a lot of Rubycons.
