Had problems burning using DVD shring with Any DVD running in background on:
Iron Man 2
Twilight Eclipse
Socerer's Apprentice
Had to resort to using Clone DVD which got the job done.
Why is Shrink having a problem all of a sudden.
Have used it countless times to do backups with perfect results.
Results 1 to 10 of 10
Why so hostile?
Burnt hundreds of dvd's no problem. Not doing anything different and it's user error. I don't think so pal.
It seems to be just the newest hits as others burn fine. -
;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Guys I usually do the dvd authorization then put it to the HD. After that I burn using nero.
Airbender gave me some fits also.
DVD Shrink wouldn't even start to authorize the dvd.....the doesn't recognize dvd came up right away.
On some of the forums people say the popular DVD's have a new copyguard that is hard to bypass.
I don't know why I get it done using Clone DVD, I was hoping to find an answer here. -
Again....you are using terms that make no sense. You obviously jumped into the middle without learning the process
and how stuff works from start to finish.
Of course DVDShrink alone will NOT work on new DVDs without help. AnyDVD running in the background should enable DVDShrink to do it's job but on the other hand I don't blame the makers of AnyDVD for not ensuring it's product works in conjunction with someone elses 8 year old(?) product.
AnyDVD is a ripper(besides being able to decrypt in the background)...it does not compress the video.
DVDFabDecrypter(the free portion) is a ripper....it does not compress the video.
You use a ripper......THEN open it in DVDShrink if you need to compress or re-author. DVDShrink opens DVD folders too...and ISO images.
Video Errors Ripping ..
By donotron in forum Blu-ray RippingReplies: 1Last Post: 7th Dec 2011, 22:45 -
How can I shrink these files. I am getting errors.
By moosooo1 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2010, 10:49 -
How to shrink the file size of 7.63GB after ripping the DVD?
By coy228 in forum MacReplies: 6Last Post: 16th Jun 2009, 09:19 -
Latest solution in ripping and shrinking DVDs?
By SirDracula in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2008, 14:25 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 03:22
