Hello guys, I'm new to this forum but I thought joining it might help me out on a little problem I have.
The problem is that, in MPEG Streamclip, regardless of what the input resolution of a video is, whenever I select convert to 3gp, it always comes out to 176x144.
I realize that this is probably like a "standard" size for 3gp format videos, but I find that strange because my phone takes videos in 3gp but at 320 x 240.
I am yet to find another format that works on my phone (LG prime) for videos, so atm 3gp is my only option. Even though 176x144 can be watched... it is not very enjoyable as it is quite blurry when stretched any.
Therefore my question is, is there a way to change the resolution of 3gp videos in MPEG Streamclip? I tried converting a video in VisualHub to "flash" format, which was recognized but I got an error saying the file size is too big (it was only about 9 megs). I dont have this limitation (to my knowledge) on 3gp because I converted a 700 mb avi movie to 3gp and it was able to play it (albeit at the aforementioned resolution).
If MPEG Streamclip can't do it, do you have any suggestions for other applications that can do this?
Thanks in advance,
Albert
Did you actually convert the file or do you just see it as an option? Because I can chose 320x240 but at the end of the conversion the file is still 176x144.
Please let me know. And if it does come out to 320x240 in the end can you tell me what version of MPEG Streamclip you have? -
Ouch. Yes I did actual conversions. File variations and setting variations, to see if my procedure would 'break'. But it didn't break.
Note that the Frame Size in the main Other Formats window is ignored, only the image size setting in the Options (3G Export settings) window counts for the final output.
I tried both 1.9.2 and 1.9.3b4.
Rotate 3GP Videos at 270 degree Angle
By ParryD in forum Portable VideoReplies: 13Last Post: 9th Feb 2015, 01:37 -
Importing 3GP videos to iMovie 11
By curt00 in forum MacReplies: 2Last Post: 3rd May 2011, 11:23 -
3gp videos from mobile run too fast in computer
By DeltaTango in forum Video ConversionReplies: 2Last Post: 1st Oct 2010, 06:17 -
Converting Muxed videos using Streamclip
By cfrei in forum MacReplies: 6Last Post: 27th Apr 2010, 09:49 -
What codec to play 3gp videos?
By Immortal25 in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2007, 10:12
