I don't understand how .srt files for video files with different fps differ, if they don't take fps into a count ( the form is HH:MM:SS,MS). I guess it does actually takes fps into a count, but how? I mean, it is represented using hours, minutes,secons and miliseconds, so it shouldn't matter since fps only determines how many frames are in 1 sec, but one sec is still one sec?
It's a newbie question (I know) but I still need it for a uni c++ project.
Thanks in advance.
Framerate determines how long the video lasts so, for example, the timings will be different for a film on a 25fps PAL DVD than they will be on a 23.976fps NTSC DVD. For a hundred minute film the PAL version will be a bit over 4 minutes shorter as compared to the NTSC (and the theater) version. The timings in the SRT files for the NTSC and the PAL versions will reflect that.
Why? It's self-evident. A film has a fixed number of frames. Surely you can understand that if those frames are played at 25fps the film will complete more quickly than it will if they're played at 24fps, right? Therefore, for the PAL version the dialog will occur progressively earlier as the film progresses. At the very beginning the dialog between the 2 versions might match up. By the end of a 2 hour movie the PAL dialog might precede the NTSC dialog by about 5 minutes. That's the only way the SRT files of the 2 movies will differ - by the differing timings.
Frame Rate Conversion
By roberto188 in forum Video ConversionReplies: 17Last Post: 5th Mar 2011, 11:11 -
Slow Frame Rate
By tobymac in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 10th Mar 2008, 14:12 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15 -
nero frame rate
By bong1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 30th Jul 2007, 16:50
