I transferred a file over to my PC from my Tivo and decoded it from .tivo to .mpg with Tivo Decoder. The file is over 9GB. I started converting with Handbrake but it said it would take over 19 hrs! I have an AMD Athlon 64 processor 2.39GHz with 3GB ram so I cant see why it would take so long. Can anyone recommend a (free) alternative? Thanks.
just used xmedia recode. Worked well but still took about 16 hrs to encode. Is that normal?
Give more info. Like 1920x1080 h264 will take time.
1920x1080 ac3 passthru h264. I had it set to not change frame rate (23.976) but it did anyway to 50 something. The quality was terrible (looked like a 700mb avi file). It came out to almost 4gb which is what i wanted. I had constant bitrate set to 5000. The source material was better than dvd quality but not blu. I guess I'll try handbrake again when i dont plan on using my pc for 19 hrs.
how to convert mkv or vob to mpg or mpeg
By ashe09 in forum Video ConversionReplies: 2Last Post: 11th Oct 2011, 04:05 -
How Convert MPEG To MKV
By noam_7 in forum Video ConversionReplies: 6Last Post: 22nd May 2011, 15:59 -
Need a Program to convert avi/mkv/ogm to dvd that is free for winxp
By animefanx in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2009, 03:22 -
What is the easiest program to convert MKV to AVI (without audio)
By Mylo in forum Video ConversionReplies: 2Last Post: 22nd May 2009, 16:52 -
Reccommend a good encoder from avi/mkv to mp4
By ir0n_ma1den in forum Video ConversionReplies: 2Last Post: 10th Jun 2008, 19:11
