Hello,
I have a older Dell Latitude D600 laptop that has a Type II PC Card (PCMCIA) slot. Do they make a wireless N adapter to fit my laptop? I don't want to use one of my only two usb ports for a usb N adapter. I found this one at NewEgg but not sure if it is for Type II PC Card (PCMCIA) slot. Confused on the wording of the interface type .
http://www.upenn.edu/computing/provider/docs/hardware/latituded600.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16839156004
http://homestore.cisco.com/en-us/outlet/adapters/linksys-WMP600n-PCI-RM_stcVVproductId...VVviewprod.htm
its a refurb but i have 2 and they work perfect and thet are guaranteed!
and for 19.99 you can't beat this deal!
this is the type II also! -
help me to choose PCMCIA capture card
By byair74 in forum Capturing and VCRReplies: 2Last Post: 5th Jan 2012, 07:45 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 05:50 -
Best Wireless Utility that can be used with any wireless card
By mol3000 in forum ComputerReplies: 4Last Post: 7th Jul 2009, 12:29 -
Wireless Laptop Problem
By The Monkees in forum ComputerReplies: 3Last Post: 17th Apr 2009, 04:52 -
Laptop wireless card help...
By rubberman in forum ComputerReplies: 12Last Post: 8th Aug 2007, 22:48
I hope it works with my Dell Latitude D600. It has a Type II PC Card (PCMCIA) slot
