Hi
I am encoding an mkv file into elementary MPEG2 Streams in AVS2DVD
The process starts just fine untill it reaches the audio enconding, then the progams stops and I get an error.
Since I usually start the encoding before I go to sleep I'm unable to tell if the problem happens at the beginning or at the end of the audio encoding.
The error is : "PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS"
I have already tried switching Wavi+Aften for FFmpeg+Aften in the audio preferences and I got the same error. This time I can tell I got the error at the end of the audio encoding. Plus the audio encoded file is 0 kb.
I have then tried switching FFmpeg+Aften for QuEnc in the audio preferences and the audio process completed without errors.
But the encoded audio file appears to have no sound when I play it.
Plz help.
I thank You in advance...
P.S.: I have noticed there is a new version of AVS2DVD (v.233). Meanwhile, I'll download it and check if the problem persists.
Cheers
Here's one of the log files:
<30-11-2010 0:57:00>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: MPEG2 Streams
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\1\Demuxed
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Source Filter: DirectShowSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 0
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 1
PAL SpeedUp: 1
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: KO - Korean
DVD Subs Language: PT - Portuguese
DVD Subs Font: Arial 22pt
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D: HL-DT-ST DVDRAM GSA-T20N WW01
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Save General Settings: 0
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: C:\######\Sympathy.For.Lady.Vengeance.2005.BDrip.7 20p.x264.DTSHD.Audio-CHD.mkv
Info: AVC - 3804 kbps - 1280x544 - DAR 2,353 - 23,976 fps (CFR) - Progressive - 1:55:09 hours - 165668 frames
Audio 1: C:\######\Original\Sympathy.For.Lady.Vengeance.200 5.BDrip.720p.x264.DTSHD.Audio-CHD.mkv
Info: DTS - 1536 kbps - CBR - 6ch - 48000Hz - 16bit - 1:55:09 hours - Internal
Subs:
[MediaInfoLib - v0.7.35]
AVISYNTH SCRIPT
Video = DirectShowSource("C:\######\Sympathy.For.Lady.Veng eance.2005.BDrip.720p.x264.DTSHD.Audio-CHD.mkv", fps=23.976, audio=false)
Audio = DirectShowSource("C:\######\Sympathy.For.Lady.Veng eance.2005.BDrip.720p.x264.DTSHD.Audio-CHD.mkv", video=false)
Video = Video.ConvertToYV12
#Using AssumeFPS() to upsize FPS
Video = Video.AddBorders(0,74,0,74)
Video = Video.Spline64Resize(720,576)
AudioDub(Video, Audio)
AssumeFPS("pal_film", sync_audio=true).ResampleAudio(48000)
START VIDEO ENCODING OPERATIONS
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3236,6 MB
HCenc Parameters: -ini "C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD.HCenc.ini"
HCenc ini file:
*INFILE C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance.2 005.BDrip.720p.x264.DTSHD.Audio-CHD_1.avs
*AVSRELOAD
*OUTFILE C:\######\Demuxed\DVD_0_Sympathy.For.Lady.Vengeanc e.2005.BDrip.720p.x264.DTSHD.Audio-CHD.m2v
*LOGFILE C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance.2 005.BDrip.720p.x264.DTSHD.Audio-CHD.HCenc.log
*MAXBITRATE 7964
*BITRATE 4097
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<30-11-2010 8:02:15>
END VIDEO ENCODING OPERATIONS
Created File: C:\######\Demuxed\DVD_0_Sympathy.For.Lady.Vengeanc e.2005.BDrip.720p.x264.DTSHD.Audio-CHD.m2v (3237,7 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4125 kbps - 720x576 - DAR 1,778 - 25 fps (CFR) - Progressive (TFF) - 1:50:26 hours - 165666 frames
<30-11-2010 8:02:16>
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg (WAV) Parameters: -i "C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.avs" "C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.wav"
Aften (AC3) Parameters: -b 1536 -pad 0 -dynrng 5 -bwfilter 0 "C:\######\Temp\DVD_0_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.wav" "C:\######\Demuxed\DVD_0_Sympathy.For.Lady.Vengean ce.2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.ac3"
<30-11-2010 10:59:16>
START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -threads 2 -i "C:\######\Original\Sympathy.For.Lady.Vengeance.20 05.BDrip.720p.x264.DTSHD.Audio-CHD.mkv" -map 0:1 -y -vn -acodec ac3 -ac 6 -ar 48000 -ab 1536k "C:\######\Demuxed\DVD_0_Sympathy.For.Lady.Vengean ce.2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.ac3"
<30-11-2010 11:00:27>
PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS.
CHECK LOG FILE <C:\######\DEMUXED\DVD_0.LOG> FOR MORE INFO.
<30-11-2010 11:00:28>
Log file created by AVStoDVD Release 2.3.2
And here's the log file when using QuEnc
<02-12-2010 15:23:33>
START PROCESS
PROJECT SETTINGS
DVD Label: DVD
DVD Menu: No Menu
PREFERENCES
MultiThread: 1
Video Resolution: 0
AC3 Audio Encoder: 2
PAL SpeedUp: 1
DVD Audio Format: 0
Normalize Audio: 0
Save Log file: 1
Video: C:\######\Original\Sympathy.For.Lady.Vengeance.200 5.BDrip.720p.x264.DTSHD.Audio-CHD.mkv
Subs:
AVISYNTH SCRIPT
Video = DirectShowSource("C:\######\Original\Sympathy.For. Lady.Vengeance.2005.BDrip.720p.x264.DTSHD.Audio-CHD.mkv", fps=23.976, audio=false)
Audio = DirectShowSource("C:\######\Original\Sympathy.For. Lady.Vengeance.2005.BDrip.720p.x264.DTSHD.Audio-CHD.mkv", video=false)
# Workaround to fix QuEnc multichannel audio mapping bugAudio = Audio.GetChannel(1,3,2,5,6,4)
HCenc Parameters: -ini "C:\######\Temp\DVD_1_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD.HCenc.ini"
HCenc ini file:
*INFILE C:\######\DVD_1_Sympathy.For.Lady.Vengeance.2005.B Drip.720p.x264.DTSHD.Audio-CHD_1.avs
*AVSRELOAD
*OUTFILE C:\######\Demuxed\DVD_1_Sympathy.For.Lady.Vengeanc e.2005.BDrip.720p.x264.DTSHD.Audio-CHD.m2v
*LOGFILE C:\######\Temp\DVD_1_Sympathy.For.Lady.Vengeance.2 005.BDrip.720p.x264.DTSHD.Audio-CHD.HCenc.log
*MAXBITRATE 7964
*BITRATE 4097
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 40
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<02-12-2010 20:25:41>
Created File: C:\######\Demuxed\DVD_1_Sympathy.For.Lady.Vengeanc e.2005.BDrip.720p.x264.DTSHD.Audio-CHD.m2v (3237,7 MB)
<02-12-2010 20:25:42>
QuEnc (AC3) Parameters: -i "C:\######\Temp\DVD_1_Sympathy.For.Lady.Vengeance. 2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.avs" -o "C:\######\Demuxed\DVD_1_Sympathy.For.Lady.Vengean ce.2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.ac3" -priority 5 -1 -nohq -novbr -mpeg2mux novideo -audiocodec ac3 -audiobitrate 1536 -auto -close
<02-12-2010 20:52:28>
END AUDIO ENCODING OPERATIONS (Track 1)
Created File: C:\######\Demuxed\DVD_1_Sympathy.For.Lady.Vengeanc e.2005.BDrip.720p.x264.DTSHD.Audio-CHD_1.ac3 (50,6 MB)
OUTPUT AUDIO INFO: AC3 - 64 kbps - CBR - 6ch - 48000Hz - 16bit - 1:50:26 hours
Closed Thread
.MKV to DVD with avs2dvd - error
By akakiami in forum Video ConversionReplies: 5Last Post: 9th Feb 2011, 03:38 -
AVS2DVD audio error
By Motinha in forum Authoring (DVD)Replies: 13Last Post: 25th Dec 2010, 22:51 -
avs2dvd conflicts question?
By VicSedition in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2010, 04:32 -
Avs2dvd Hcenc differences...
By VicSedition in forum Video ConversionReplies: 3Last Post: 16th Mar 2010, 02:09 -
avs2dvd ? bitrate failure
By VicSedition in forum Video ConversionReplies: 5Last Post: 8th Mar 2010, 16:02
