Hello, everybody.
In my SETUP the Boot Sequence is:
1 - DVD
2 - Hard Disk
3 ---
4 ---
but when I put the CD Windows XP SP3 and reboot the PC, it doesn't boot from the CD.
What must I do?
Cheers.
try a different cd like a linux bootable one. if it works then the xp cd is bad.
The CD XP functions in other PCs. So it's not bad.
Anyway I made a new copy but the problem maintains.
With the Windows XP SP2 there are no problems! -
Probably DVD/CD drive not functional correct with specific type of media.
If computer have DVD drive, try burn it to DVD media not CD.
And try boot from DVD media -
Could be a BIOS issue.
In PC's I have seen, I have to hit a key when instructed to 'Boot from CD' during start-up. If that instruction times out then the PC boots from the next drive in the chain - the HDD -
On some systems where the disc is ignored and enters os you can temporarily disable the hard drive as a bootable device to allow repairs or reinstall to be carried out ... should the system require a reboot to continue simply re-enter bios and re-enable the hard drive as a boot option.
Remember you are talking about "multiple systems" where two other units have no problem but this system dose ... it may simply be that the drive on this unit requires updated firmware or is picky about the media brand being used.
Boot CD
By Tommyknocker in forum Software PlayingReplies: 2Last Post: 24th Mar 2012, 21:59 -
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
boot issue
By MJA in forum ComputerReplies: 14Last Post: 8th Feb 2010, 15:11 -
Boot Problems
By Sakuya in forum ComputerReplies: 10Last Post: 4th Nov 2009, 23:22 -
pc will not boot up
By mickdee259 in forum ComputerReplies: 7Last Post: 26th Apr 2008, 05:15
